Old 03-07-2016, 10:06 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default MillerBuilt's WELD-ON C6/7 Hybrid Floater System
Full Floater System -
These NEW billet steel Adaptors Weld-On to nearly any axle tube!
Advantages:
  • Welds to your new OR existing housing
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th/6th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th/6th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Fitment: Any rear-end with 2.750”-3.250” o.d. axle tubes
See information listed below for both the "long" and "short" versions...
Weld-On “Short" Floater Kit (pictured below)
E-brake Assemblies & E-brake Cable Brackets NOW INCLUDED With Each Floater Kit
Full Floater Kit (Short) Includes:
• (2) Billet Steel Short Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) SKF 33 Spline Hub Assemblies
• (2) E-brake Assemblies
• (2) E-brake Cable Brackets
• (1) Install Kit
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICING AT - https://millerbuiltusa.com/universal-weld-on-base-kit/
Full Floater Kit (Long) Includes:
• (2) Billet Steel Long Floater Adaptors
• (1) Install Kit
Have interest?
Have questions?
Need more info?
Distributor Inquires Welcome!
To help determine which kit might work best for your particular application, please see below picture.
"Weld-On" kit in action!
Questions welcomed!
Last edited by MillerBuilt; 08-20-2018 at 10:03 PM. Reason: Updated Info & Price Adjustments
Old 08-06-2016, 12:53 PM
Default FREE Shipping & PayPal This Weekend!!
FREE Shipping & PayPal This Weekend!! (8/6/16 & 8/7/16 - "lower 48" states only)
Old 10-06-2016, 10:16 PM
Originally Posted by MillerBuilt View Post
FREE Shipping & PayPal through October!! ("lower 48" only)
This........ (floater ends)
Gets you to this..... (complete hybrid full floater system)
Housings can be supplied as well for a complete solution......
Thanks for looking!
Old 06-05-2017, 08:18 PM
Default In Stock
In Stock
Old 09-02-2017, 08:42 PM
Default Customer Ride
Recently received a few orders from Donny over at Frame Up Wheel Works. Donny/Frame Up is out of Beach Park, IL. Donny's builds speak for themselves and I am thrilled to have him on board with the MillerBuilt Full Floaters!
Donny is well versed in what it takes to properly fixture the MillerBuilt Weld-On Full Floater. Donny felt the MillerBuilt Hybrid Full Floater System was the best solution for what he was looking to accomplish. Per Donny,,,,, mission accomplished!
Below is the beautiful 69' that one of the MillerBuilt kits sits under. The car frequents both Auto-X and Open Track Days....
Old 09-04-2017, 08:04 AM
dontlifttoshift's Avatar
Thanks Jay!!
Here is another that we did.
Using the long snout weld on kit, I was able to widen the rear end so that I could run a square wheel and tire setup helping our consumables last longer.
Donny
Old 12-18-2017, 08:56 PM
Default Ridetech Chose MillerBuilt for its Full Floater Needs!
MillerBuilt is very proud to be a part of the new Ridetech Track 1 Camaro build!
Follow along as this beast comes to life...
http://www.ridetech.com/info/categor...project-build/
Old 08-12-2018, 12:29 PM
Default Get Yours
In Stock!
Old 08-03-2019, 01:23 PM
badazz81z28 badazz81z28 is offline
Theres a thirst for more info on these kits. They now come as bolt on which is very nice. Do you offer axles? Is there an inner axle seal with the kit? Will the ear spacing on the caliper bracket fit aftermarket brakes like Baer 6P and SS4?
Old 08-03-2019, 05:58 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I bought Jay’s weld on kit. Very quality kit and his customer service is great. Every time I called with a question, he either answered the phone or called me back with great tech support too. I highly recommend his parts. Yes, he supplied me with axles as well. His kit comes with everything you need and I told him what brakes I'd be running also. I'm running Baer 6S Extreme kit on the rear.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
MillerBuilt (08-15-2019)
