Old 02-13-2018, 11:39 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default LSA Detroit Speed
Looking for someone who may have experience with putting an LSA in a Detroit Speed Subframe- second gen Camaro. I'm thinking I may have a clearance issue with the crank pulley hitting the frame where the sway bar lives. I was told by DSE that the sub frame was not designed with the LSA in mind. Any input would be appreciated.
Old 02-14-2018, 09:17 AM
JON Q's Avatar
JON Q JON Q is offline
Do a search here for the project Lou's Change built by V8TV. It's a 69 Camaro with DSE and LSA motor.
Old 02-14-2018, 10:15 AM
randy randy is offline
crank pulley doesnt hit. If you want low mount ac you will have to notch the passenger subframe. Buy the lsa and get a front runner kit and your done.
Old 02-14-2018, 07:22 PM
DKz Garage's Avatar
I dropped in on that thread (awesome build!), I just wondered how the first gen build would compare to the second gen?? I know both DSE frames use first gen rails...at least that's what I was told..... Thanks for the input!
Old 02-14-2018, 07:24 PM
DKz Garage's Avatar
Thanks Randy! I was hoping that was the case Have you done the LSA/second gen build?? Any pics??
Old 02-15-2018, 12:06 AM
Helped yes.
Www.rodscarcraft.com
Look up trevors 69 convertible. All the blocks are the same dimensions
Old 02-16-2018, 10:11 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Wegner has a very nice accessory drive for the LSA.
Jason Mitchell
1971 Camaro 416 LT1 Project
