Old 07-25-2017, 09:51 PM
thedugan's Avatar
thedugan thedugan is offline
Jeff (JWCARGUY) mounted his where the firewall meets the trans tunnel and it's covered by his 5th gen console. Very easy to get to if need be. Might be worth a PM to get a few more details on that and how he setup his console with the gauges.
thats a really nice setup.
did a search and this is a thread on the console setup
https://lateral-g.net/forums/show...t=42957&page=2
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 07-30-2017, 12:07 PM
jwcarguy jwcarguy is offline
Banned
Hi Has anyone got pictures of their ECU mounted replacing the glove box or anywhere under the dash for a first gen Camaro?
Thanks in advanced.
Wayne
Wayne
It would help if you said which pcm that you have?
I am running a Gen III "411" pcm, which is the largest of them
Using a GM mounting bracket, slightly modified and have the pcm mounted horizontally on top of trans tunnel @ firewall ( GM#15995679 mount)
it sits just under the custom 4 gauge pod that is in my console
The engine harness relay bank and fuse panel are mounted to firewall ( laid out/ mocked up with Vintage Air unit & hoses prior & welded mounting studs prior to firewall finishing), just above accelerator pedal for ease of servicing/ access
the OBD II port is just under dash, adjacent to steering column
Using the glove box insert from Vintage Air kit
I will do the same on Curtis's car when it comes to my shop in next day or two
Hope this helps
Jeff
Old 07-30-2017, 02:10 PM
Love that! Excuse me while I hunt for a console on ebay
Old 07-30-2017, 06:32 PM
Thanks Jeff, I'll definitely be watch the progress on that car! Sorry it's an E67
