Old 12-04-2009, 11:07 PM
dlouie87's Avatar
dlouie87 dlouie87 is offline
Default Best Wheel Size combo for a 67 Camaro?
18s all the way around with 8'' in the front and 9'' in the rear
or a staggered set of 18/19 or 17/18?
Old 12-04-2009, 11:10 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
18s all the way around!
Curtis
Old 12-04-2009, 11:34 PM
dlouie87's Avatar
Thanks curtis.
I was looking at your camaro and I was wondering...
How'd you make the 18x10 fit in the rear of yours?
Old 12-05-2009, 04:21 AM
deuce_454's Avatar
Thanks curtis.
WOW.. you need to use the search function... there are a million posts on that sublect... the most used way is the minitub... with or without changes to the rear suspension..
it would seem the new upcomming fad is widening the fenders check the post "fat bottom camaros"
Jake: Hit it.
Old 12-05-2009, 10:06 PM
dlouie87's Avatar
I did use the forum search and I've been looking on other forums. I was asking him about his specific set up.
I was just seeing if I can fit a 18x10 without a mintub on a 1967. As I was SEARCHING and looking through Spiffav8 post and mod list. I dont think he has a mini-tub job.
-Dan
Old 12-05-2009, 10:13 PM
JustinB's Avatar
JustinB JustinB is offline
Dan,
18x8 and 18x9's. 19's are tough due to the fact that 19's are not available in a 9" wide hoop in the wheels you were interested in unless we narrow it for you.
Justin
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 12-05-2009, 10:19 PM
skatinjay27's Avatar
-Dan
your correct dan he doesent have minitubs, the fender are just rolled and the b.s must be spot on, he was also run a 285 tire.
AJ
