Old 05-05-2017, 08:34 AM
Juicypop Juicypop is offline
Originally Posted by Che70velle View Post
I'm using AutoMeter Ultra-lites. Mine are bright at night, in fact so much that I have to dim them down some. I would think that you have a possible dimmer switch issue? Something doesn't sound right... I would trouble shoot the issue extensively before you ditch what you have.
Now on the other hand, the Racepak stuff is sick!
As stated we called them and we will trouble shoot what they said to do.
Originally Posted by Jr View Post
Which shifter is that?
Also, race paks are functional and bitchen. I vote race pak.
B and M stealth shifter.
Originally Posted by LateralJeaz View Post
Any night pics? Just curious as I also have some speedhut gauges on the way..
I am picking up my car from the tuner today. When I get it back home will get some pics.
Originally Posted by Sheck44 View Post
I've used 3 sets of Speedhut gauges and have never had an issue with the brightest. I'm assuming you are using the Spedhut dimmer switch with your setup.
Btw .. I now have a Racepak IQ3s in my camaro and on full brightness it's like sitting in a spaceship LOL
Cheers
Steve
Yah the dimmer switch would not change the look.
Originally Posted by will69camaro View Post
No lie there. I think I have my brightness of the screen on 3-4 out of 10.
Nice!
Originally Posted by 130fe View Post
I love my Dakota Digital HDX gauges. I have had both them and the VHX series and have no issues at all. Using their OBD 2 BIM module, it transmits all of the PCM readings to the gauges. Each gauge has a warning light and you are able to change the colors of the gauges.
Those look great!
Old 05-05-2017, 08:43 AM
carbuff's Avatar
carbuff carbuff is offline
I'm very happy with my Speedhuts. I did not choose anything out of the norm for color/background combinations though. It sounds like your issue is with the appearance as opposed to the function, correct?
Old 05-05-2017, 10:29 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
Love my Speedhut gauges.
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
Old 05-05-2017, 11:35 AM
It is both but as I said I contacted them and when get the car from the shop will try what they said to do.
That is a great looking interior brother on your car!
Thanks!
Old 05-05-2017, 03:33 PM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default Racepak
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
Old 05-05-2017, 05:26 PM
Wow what a interior you have there very sick brother!
Old 05-05-2017, 11:01 PM
transam's Avatar
transam transam is offline
I prefer racepak over actual gauages. Its bright, the programmable shift lights are bright and easy to follow. The downside is if your ecm isnt compatible with all the inputs you need to buy modules for each item you want to monitor which can get pricey.
Old 05-06-2017, 03:16 PM
Looks sick. Thanks for the input.
Old 05-06-2017, 08:57 PM
Hydratech®'s Avatar
Hydratech® Hydratech® is offline
Supporting Manufacturer
HydratechBraking.com
Wink LED lighting
I have been doing an awful lot of work retrofitting every vehicle we have to the new LED lighting systems. For instance, I have always had a hard time reading my factory gauges on my 442 at night, installed higher output W5W bulbs only to end up building too much heat and melting things (!) The W5W bulbs were better than the 194 bulbs, but not that much. Then I installed some JDM ASTAR 194 replacements and WOW - the gauges are now damn clean and bright and zero heat issues:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have actually become highly addicted to JDM ASTAR products / latest gen LED automotive lighting from other brands too. Some of the bulbs are not cheap, but the results are amazing. It cost me some blown fuses and a wrecked turn signal switch before I researched the difference between a "CK" and a standard socket (sucked), but still tickled silly with the end results. And then there was the hyperflashing issues that gave me another learning curve too (specialized old school flashers designed for LED conversions), and also load resistors on the newer cars where the flasher is handled by the damn BCM...
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark <-- the Ukrainian - Slava Ukraini !
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 05-08-2017, 12:38 PM
This is great information thanks brother.
