Old 01-08-2018, 01:16 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default LSA Accelerator Pedal Assembly
Quick question regarding the correct accelerator pedal to use on my LSA/70 Camaro build. A little background: I have a complete BP automotive wiring harness for my LSA swap (thanks Tom!). The harness was originally set up for a LSA + 4l60e trans, I have decided to run a T-56 manual trans. So I know I need to have the wiring converted for the manual trans, which is no big deal. Doing some research, GM had two different Accelerator pedals for the 2009 CTS-V (manual vs Auto)...not sure what the difference would be?? I've read that a C6 Corvette pedal would work??
Looking for input on what pedal will be compatible with my harness...and be the cleanest install in a 2nd gen Camaro??
As long as I am looking for input....Has anyone run into issues with the Crank Pulley on an LSA engine having clearance issues with a DSE sub-frame (2nd gen Camaro)??
Thanks in advance....
Old 05-01-2018, 03:01 PM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
I would contact harness maker about the pedal assy I know you can buy them for ZL1 but they have some bling trim added to them now as far as 4l60 or a T56 neither will work long for that power level the LSA uses a dual disc clutch the will fit in the TR6060 bell housing that opens a whole new can of worms - the shifter is external and mounted back far so it will all need some modifying
I was looking at LSA TR6060 in my 69 bird (which I already owned) I decided to build a ZL1 and keel my LS6 T56 in my bird. I'm happy I did it this way
hope this helps out
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 05-22-2018, 10:10 PM
andrewb70's Avatar
C6 pedal will work. I also like the 2009 Impala SS pedal, and it will work as well.
Andrew
Instagram @projectgattago
I deliver what EFI promises.
My YouTube Channel
