Unread 12-22-2017, 09:11 AM
l2azorback l2azorback is offline
Default 1969 Camaro Parts - Vaporworx, Lemons BBCs and more
Item Location (City/State): Little Rock, AR
Price: listed below for each item, and includes shipping (CONUS)
Payment Options: Paypal Gift or =4% for fees, Invoice from V8SR and you can use your debit/credit/bank draft at your discretion. You will need to send you email, and I will have Kelle at V8SR send you an invoice. This will be cross-posted on Pro-T as well.
Description:
I have some parts coming out of my car with approximately 500 miles on them, as I am swapping from BBC to LT4: The pictures included are during original installation and do not depict the current condition.
- CTSV Fuel Pump Module - $OLD
- Vaporworx PWM Controller (harness and FP sensor) - $OLD
- American powertrain X Factor T-56 Crossmember - $220.00
- Lemons BBC Headers (2-inch Primary's) (Fits DSE Sub Frame), Freshly Ceramic Coated prior to installation and V-band clamp collectors - $900.00
- Quicktime SFI bellhousing for BBC/T-56 Magnum - $OLD
- Centerforce DYAD for BBC/T-56 (Flywheel, dual disc clutch and Pressure Plate) - $1225.00
Please let me know if you have any questions. I will attempt to get pictures as the car is currently at V8SR for the motor swap.
Regards,
Larry
Unread 12-22-2017, 05:01 PM
Do you happen to know the tube size on the headers? 2" or 2 1/8"?
Thanks,
John
John
'71 Nova (Build thread)
FFR Roadster
Unread 12-22-2017, 05:49 PM
I believe they are 2 1/8 or 2 1/4. I can get back to you.
Unread 12-28-2017, 08:32 PM
jdeliveryguy jdeliveryguy is offline
pm sent
Unread 12-29-2017, 05:17 PM
Lemons BBC Headers are Two-Inch 2" 2-in.
Unread 12-30-2017, 08:00 AM
Tinker's Avatar
Tinker Tinker is offline
Sure, Larry now you decide to sell the fuel pump and controller.
I bought your tank earlier, any chance you want to sell the Vaporworks controller and harness separate from the pump? I already purchased a fuel pump.
Chris
Unread 12-30-2017, 08:40 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Looks like an awesome setup! Why the switch...?
Unread 01-02-2018, 09:30 AM
Chris, If I was able to find someone just wanting the pump I would be willing to separate.
I had no idea when I went down the Gen V LT4 route that I would not be able to keep my current set-up. This is the best fuel system set-up, but it will not sustain enough continuous fuel pressure needed for the direct injected LT4.
Unread 01-02-2018, 09:31 AM
Gen V LT4
Speed Density technology on the Holley HP system vs. the latest tech on the GenV LT4. Much more streetable for my style of driving.
Regards,
Larry
Unread 01-02-2018, 09:02 PM
jps68camaro's Avatar
jps68camaro jps68camaro is offline
Default - American powertrain X Factor T-56 Crossmember - $250.00
Larry,
Sent you a PM regarding this-
James
68 Camaro in the works
02 LS1 with Fast 92 (internals still work in progress)
T-56 banger
TVE Front Suspension with Global West Tubes
Thinking of Quadralink for the rear suspension
vB code is On
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
