Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 10-17-2013, 03:00 PM
Musclerodz's Avatar
got the dse kit in. although the factory motors are the same, the way the dse motors are done, the swap is not as straight foward due to the way the motor is mounted in the trucks. I will work on a fix and see what I come up with.
Mike Redpath
Musclerodz & Customz
facebook page
Old 10-17-2013, 03:44 PM
68LS1's Avatar
68LS1 68LS1 is offline
Thanks again for update
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 10-17-2013, 03:48 PM
68LS1's Avatar
Originally Posted by tech@scotts View Post
We've installed several of the Specialty Power Window Wiper Universal kits in C-10's. Right now we're installing on in the Goodguys Giveaway C-10 that we're building. We're having a sale in the vendors marketplace, but look here for pics of the kit. Just throwing it out there as another option if you're interested.
https://lateral-g.net/forums/showthread.php4?t=43348
Thanks, will see how Mike goes with the DSE kit
Is the Specialty Power Window Wiper Universal kits only 2 speed no intermittent/delay?
Roger
Old 10-17-2013, 06:06 PM
Scotts Hotrods Scotts Hotrods is offline
Supporting Vendor
The specialty power window wiper kit has a 2 sp and intermittent switch.This kit is made in the USA.Like stated before it is a option to what Mike is offering.
I will say one thing we have sold more 100 of theses kits and they will work perfect and are a great fit in a c-10 truck.We do build alot of C-10s in our shop
Old 04-27-2015, 07:54 PM
longhornss longhornss is offline
This is an old post I know but was there ever any resolve on the Detroit speed install?
Old 08-26-2015, 06:04 PM
Ambition Road Ambition Road is offline
Just finished installing a DSE Selecta-speed wiper kit in our 67 c10. I started with a 67 camaro kit. They do have a universal kit but they were on back order and we found this one in stock from a dealer. It can't be a "bolt in" since the stock bracket must be removed, but wasn't very difficult. It took about 3 hours to do.
Aaron Elenbaum
www.ambitionroad.com
[email protected]
704-608-6967
*Now scheduling full turn-key custom builds
*Sheet metal restoration and replacement
*Pro-touring rollers
Follow all our builds on FB--> https://www.facebook.com/Ambitionroadllc
Old 08-26-2015, 06:06 PM
First the stock mounting bracket had to be removed by drilling the 6 spot welds
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:07 PM
Bracket is out of the way
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:10 PM
Using the 67 camaro bracket as a template, it was cut to fit. The edge on the left fit perfectly vertical with the motor mounted at an angle out of the way with no interference.
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:14 PM
1/8" steel plate was used. This gives the right spacing for the shaft to protrude thru the cowl. The shaft hole is slightly smaller than the DSE plate to seal around the rubber grommet.
Aaron Elenbaum
[email protected]
704-608-6967
