Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 08-26-2015, 06:15 PM
Ambition Road Ambition Road is offline
The plate is plug welded in place with a few stitches around the perimeter.
Aaron Elenbaum
www.ambitionroad.com
[email protected]
704-608-6967
*Now scheduling full turn-key custom builds
*Sheet metal restoration and replacement
*Pro-touring rollers
Follow all our builds on FB--> https://www.facebook.com/Ambitionroadllc
Old 08-26-2015, 06:19 PM
The 3 bolt holes are drilled thru from the inside. The top bolt is above the upper tangent so it won't be flush. The upper hole was opened up to about 3/8" thru the cowl (just large enough the clear a 1/4-20 socket head cap screw)
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:21 PM
Motor is installed
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:25 PM
Inside view
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:27 PM
Musclerodz's Avatar
Thats awesome you figured it out, but sucks that DSE is currently not producing wiper motors at this time.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-26-2015, 06:28 PM
The top bolt will need to be sealed during final assembly with a small amount of 3M strip caulk.
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:30 PM
Taking measurements before cutting, the stock arm will be welded to the DSE arm with the splined hole.
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:32 PM
Tacked together, rechecking measurements.
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:33 PM
Welded and metal finished.
Aaron Elenbaum
[email protected]
704-608-6967
Old 08-26-2015, 06:36 PM
Update complete. Upon final assembly the "park" position will need to be set and nut torqued.
Aaron Elenbaum
[email protected]
704-608-6967
