Go Back   Lateral-g Forums > Technical Discussions > Transmission and Rear End
Old 03-20-2015, 10:34 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by Build-It-Break-it View Post
Have you came up with a price yet for just the adapters And seal?
Not yet, I am machining a few sets next week and once machine time is determined,,,, I can put a cost to them. I do however expect the pricing to be similar as the "weld-on" kits I sell since they are very similar, and as you may or may not know those are $900.00 a set.
Additionally, the basic kit for this "bolt-on" setup will include the axle seal and ARP hardware. Appreciate your interest! Thanks!!
Originally Posted by Rod P View Post
HOLY CRAP! thats awesome....totally want
Thanks Rod, I am VERY proud of this set-up! Would love to see you beating on a set of these soon! Let me know
Originally Posted by efs69 View Post
Stay tuned for newly machined sets
Originally Posted by 130fe View Post
Stupid question- does this make a conventional rear with torino ends into a semi-floater? Curious on pricing as well. Any info would be appreciated.
I do not think any questions are stupid and believe that is how we all learn. To answer your question, a conventional rear with "torino ends" IS considered a semi-floater. This set-up would fall closer into the full floater category.
In a nutshell, with a semi-float axle, the axle shaft both carries the weight of the vehicle and transmits torque which directly relates to the failure of bearings, seals, and ultimately piston knockback.
With a full-float axle, the weight of vehicle is supported by the axle housing-more specifically and in this situation, the C6/7 Hub/Bearing that is attached/bolted to the end of the axle tube. Torque is now transmitted by the axle shaft that carries literally no weight since the Hub/Bearing Unit supports the vehicles weight now...
Old 03-21-2015, 10:00 AM
Originally Posted by Ron in SoCal View Post
Yes, with the floating axles it should. I've run a similar weld on style flange and it absolutely has no knock back.
That implies that you actually went into a corner hard enough to move the rotor and push the pads back..... Just sayin'.... Hahahahahahahaha
Old 03-24-2015, 02:38 PM
Jr's Avatar
Jr Jr is offline
Great idea. Yes, I'm very interested.
Old 03-25-2015, 08:22 AM
Thank you Jr. I appreciate you posting up your interest.
Keep an eye on this thread for more info!
Old 03-25-2015, 12:07 PM
Payton King's Avatar
Payton King Payton King is offline
Great idea! So simple, but you are the first. Brilliant really, for the person making the upgrade with additional room or before they order wheels.
Old 03-25-2015, 02:20 PM
crazycarl's Avatar
crazycarl crazycarl is offline
Originally Posted by JSM View Post
...I do however expect the pricing to be similar as the "weld-on" kits I sell since they are very similar, and as you may or may not know those are $900.00 a set.
Does the weld-on kit for $900 include axles and the unit bearing? Gotta link to your website somewhere? There are no details in your signature or your user profile. I looked through your posts and saw a bunch of GMR stuff but when I called GMR they said you don't work for them.
I'm probably just screwing with you, so please don't take it personal.
Old 03-25-2015, 09:05 PM
Thanks Payton! Now what do I owe ya for saying that
Old 04-04-2015, 01:29 PM
4mul8ion's Avatar
4mul8ion 4mul8ion is offline
Hope this helps. These ends were from Dutchman.
Old 04-04-2015, 06:06 PM
4mul8ion's Avatar
Here's the Dutchman outer shape.
Old 04-16-2015, 01:57 PM
efs69's Avatar
efs69 efs69 is offline
Jay,
Here are some pictures of my Moser set up. It does have the inner seal as well. Hope these shots help.
