Go Back   Lateral-g Forums > Technical Discussions > Transmission and Rear End
Old 08-13-2017, 07:12 PM
DT69Cam DT69Cam is offline
Default TKO in 1st gen camaro (hole size)
What size shifter hole you guys cut for a TKO in your 1st gen Camaro ?? I have a new 1 piece floor installed and wanted to make a clean round hole. Just not sure what size. Thx
69 Camaro Convertible (LS3/TKO in the works)
Old 08-13-2017, 08:08 PM
Gregster1234 Gregster1234 is offline
Here's my install - TKO600, I haven't bolted the trans mount yet thus why it is not centered. I used a 4" metal holesaw.
Old 08-13-2017, 08:09 PM
Thank you very much!
Old 08-13-2017, 10:01 PM
JKnight JKnight is online now
You can probably get away with a slightly smaller hole in the tunnel than Greg's pics but this is one of those things where you don't need to be too precise. Just need the clearance Clarence.
Jeff: Project "Rolling Mockup" 69 Camaro SS, AFX, TKO600, Baer GT, etc
Old 08-14-2017, 01:43 PM
Thx for the reply. I was curious what other guys did. I could even just cut out the exact size of the shifter plate (for lack of better description). Its almost a rectangular shape.
