Go Back   Lateral-g Forums > Technical Discussions > Safety Equipment
Old 03-14-2015, 10:33 AM
carbuff's Avatar
carbuff carbuff is offline
My shoulder belts are wrapped to the harness bar and not bolted to it. I don't think they will slip if wrapped correctly, and it's not hard to do.
I don't have a lot of clearance to the back of my seat either, so bolting to them wasn't a good option. My harness bar is not at the ideal height: it's a bit lower than it should be.
Old 03-14-2015, 12:06 PM
Decline Decline is offline
If you are trying to use the stock belt mount locations, those bolts are larger. I think I opened up the hole on the brackets for the floor mounted belts and used the original bolts. I had different ones: some had shoulders, some were just threaded as I recall. I chose the smaller ones to open up the holes the least amount.
Also, I think the brackets are hardened which made opened up the holes a challenge.
If you are creating new mount point in the floor, then I don't see how there could be a problem.
Good luck!
This is my problem^^^
I am trying to use the stock lap belt mounts and the bolts are larger diameter.
Guess I could open up the holes on harness brackets and use the original bolts.
The rear shoulder mount is a problem cuz I was planning on running eye bolts in the stock seat belt mount location with the clip on brackets.
Looks like I either need to buy eye bolts of the correct diameter or get 4 reinforcement plates and drill some holes.
Old 04-23-2015, 05:55 PM
I eventually got the harnesses installed. I opened up the lap belt brackets with a drill bit and used the stock bolts in stock holes. For the shoulder harnesses I couldnt find a 1/2x 13 eyeblot in the right dimensions so I got backing plates and drilled holes in the rear seat area and used the Schroth hardware
Old 04-23-2015, 11:43 PM
glassman's Avatar
glassman glassman is offline
Sweet, glad you got it done. Mines still not done.
Mike
