Old 03-09-2016, 09:12 PM
I'm doin my best to shake my butt and get it in gear!
Paint for you this week Mario ??
Old 03-11-2016, 09:48 AM
E.rodz's Avatar
E.rodz E.rodz is offline
.Wayne looks like your making progress. i am pulling for you to get this thing on the road this summer! as for that pad you want to glue on don't use 3m 77 spray adhesive for that you can use 3m super 90 spray adhesive it holds up to humidity better or 3m trim adhesive it comes in small tubes you might even get is at menards.
my name is Eric Hokenson I have a dream of building ten of the coolest hot rods out of my home shop wish me luck I am going to need it! - more pics on my web site www.erodzcustoms.com this is just for fun and i am NOT looking for any more work!
Thank you supporting sponsors! without you guys there is no way I could do this myself !
Modern automotive performance,Ring bros.,Yank convertors,extreme drive systems,Cj tunes,race coatings stainless works,Modern Automotive Performance.all of these shops have the experience to get your car to the top.
Old 03-11-2016, 11:55 AM
pro66tour's Avatar
pro66tour pro66tour is offline
Looking top shelf Wayne...
GET R DONE! You both need to be on the road this summer!
Old 03-11-2016, 08:42 PM
Thanks guys! Eric I'll pick some of the super 90 up thanks for the info.
Yesterday was a productive day. My AN fittings and hose came in and today a couple of other parts came in too. When I get home from Virginia Sunday I'll crack open the boxes to see what came in. Then Monday I'll try to get to some plumbing.
Thanks Al Moreno , G5 and Morenomotorsports for all your help and support.
Old 06-05-2016, 09:42 PM
Well I went out to the car the other day and thought something was missing!
The motor had to come out to notch the sub frame for the A/C compressor. So here we go.
The motor came out easily, we put it on the engine stand so we could do some work on the remote oil filter lines. a 90 degree fitting had to be screwed into this aluminum adapter.
I was going to use two straight fittings one short and one long and 90 off them forward to the oil cooler, but the way the AutoKraft pan kicks out and how close my headers are to the oil pan it wouldn't work. I picked up a tight 90 degree ORB to AN fitting to use for the front hose, but of course it can't go in because the oil out let is too close to the base pan to spin the 90 degree fitting so off came the adapter. The inside of the oil passages on the adapter had very sharp edges so while its off My buddy (Spaceman) is cleanig them up for better flow.
The base pan I bought was used and the previous owner had it powder coated. When he did they left the spot where the O Rings seat bare, which made the O Rings probably not able to seal it up because of the thickness of the powder coating around them. Not good on an oil line. So while Spaceman was cleaning up the sharp edges I striped the powder coat off the oil pan rail while not letting any grit or crap get in the oil passages. It kept me busy for quite a while.
The discolor around the oil passages is where there was no powder coating.
And ready to reinstall the adapter. I removed all the coating where the adapter would make contact so the O Rings would get the proper pressure for sealing.
Now this part is ready to complete.
Old 06-05-2016, 09:57 PM
Now on to the Frame notch.
We geusstamted on where we would need to cut the notch with some tape. then we removed the engine.
I then put the A/C bracket and compressor ( which got ordered the day we took the engine out.) on the motor to try and see how we did with the tape.
Next was to brake out the air tools! We made some cuts.
Big cuts!!
First cut.
Need more
Second cut
Needed more
Final cuts
The small opening over the lower control arm will be filled in with 1/8"-3/16" plate, then the finish pocket for the A/C will be made in the same material.
That's where we stand right now .
Old 06-06-2016, 05:55 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Progress is good Waynie,looks good
Old 06-06-2016, 08:59 AM
pro66tour's Avatar
Those all important details that take plenty of time and rack your nerves a little. Your guesstamation was right on Wayne. Looks very sound bud
Old 06-06-2016, 09:19 AM
glassman's Avatar
glassman glassman is offline
Fun stuff Wayne!! Looks great, like every great build, ya gotta start with a good foundation...in with the engine, out with the engine, in with the engine, out with the engine....never ends lol....anyways, cheers from the golden and broke state..good luck with the remaining "easy stuff"....
Mike
Old 06-06-2016, 09:25 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
All that cutting just to tighten that lower control arm nut huh?
