Go Back   Lateral-g Forums > Technical Discussions > Engine
Old 12-29-2014, 09:24 AM
SSLance's Avatar
SSLance SSLance is offline
Default Wideband O2 sensor\gauge choices
Since I'm pulling the OBDI system out of my car and going with a programmable MSD ignition box and mechanical Quadrajet for spark and fuel, I want to put in a wideband O2 sensor and gauge to help tune the carb to the proper air\fuel mixture throughout the RPM range and keep an overall eye on things. I'm curious if anyone has much experience with a certain brand or one that they prefer and can recommend over another?
I'd like to data log but I'll already have the laptop in the car when tuning for the MSD so having a handheld to read and data log the O2 sensor isn't mandatory.
I'm kind of leaning toward the Innovative MTX L after my initial research.
http://www.innovatemotorsports.com/products/MTXL.php
Fast's system looks pretty cool as well but comes with a handheld and is more money...
http://www.fuelairspark.com/fas/gaso...le-sensorhtml/
Curious if anyone has any real world experience they can share when using a setup like the above with a carbed SBC.
Lance
Old 12-30-2014, 12:18 AM
dale68z dale68z is offline
I have an AEM. http://www.summitracing.com/parts/avm-30-4100
It has worked fine for about 2 years, 10k miles. I killed the sensor with leaded fuel. It takes very little lead to kill the sensor. A sensor cost me another 80 ish$
Old 12-30-2014, 07:04 AM
SSLance's Avatar
Thanks Dale. I like that the AEM sensor doesn't need to be calibrated regularly but that is probably why they cost so much by themselves. Looks like a good kit for a good price though.
Lance
Old 12-30-2014, 12:10 PM
Sieg's Avatar
Sieg Sieg is offline
Lance,
I recently installed the AEM unit and have zero complaints.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old 12-30-2014, 12:17 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Another AEM, carbed BBC. 500 miles so far running 50/50 premium/110 leaded.
Old 12-30-2014, 12:25 PM
SSLance's Avatar
Dang, okay... AEM it is then. Thanks everyone.
Now I just have to find a place to put the gauge. I hate that part, I'm not one to cut up my factory dash.
Lance
Old 12-30-2014, 05:34 PM
andrewb70's Avatar
andrewb70 andrewb70 is offline
Holley makes an awesome wide band controller that I have used for over 10 years. The nice thing about it is that it can be used with either the Bosch or the NTK sensor. This is basically the latest version of the FJO system (Holley bought FJO some time back).
https://holley.com/products/fuel_sys.../parts/534-201
Andrew
Old 12-30-2014, 11:55 PM
You were able to run some leaded through it?
I added 3 gallons of 110 unleaded, then filled the tank with 91. Ran a full track day. It worked fine on track and the drive home. Added fuel, next morning it was very lazy, and the next day it was stuck at 14 something air fuel.
Whatever happens with the leaded fuel, just a little makes the inside of the exhaust pipes white.
Maybe my exhaust gets hotter???
Old 12-31-2014, 07:54 AM
Ketzer's Avatar
Not sure on that? Are you letting the sensor fully cycle and "warm up" before starting the engine? I had read that tip somewhere and always try to be sure I do it. I used mine all this past summer and never noticed it getting slow or not reading accurate.
Old 12-31-2014, 08:23 AM
chickn chickn is offline
I would look for an option that allows you to log the A/F data if you want to tune all of the circuits in your carb. You can learn so much more when you plot the data. I think it may be possible to use a innovate motosports LC-2 cable and log directly to a laptop. (keeping the cost down). Have you ever looked at http://www.autosportlabs.com? They have a really nice data acquisition that is relatively cheap and open source.
