Old 02-13-2018, 03:08 PM
Default 9" pinion yoke Question
Pinion yoke question, does a Ford 9 inch rear and have to be reset if you want to change the yoke? Itís brand new never been broken in.
When you install a CV driveshaft does it matter which end the CV joint goes on when you have it built if the angles are close on both ends?
Old 02-13-2018, 04:04 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Depends on where the rear end was sourced. I know many of them use shims/spacers, rather than a crush sleeve, so there is just a torque rating and that's it.
-Dale
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 02-13-2018, 11:08 PM
Thanks Dale.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
