Old 10-16-2017, 09:05 PM
kward kward is offline
Default 69 Camaro LQ4 Swap which oil pan?
Just curious if there is an oil pan that will clear the crossmember and steering links without modification. Put an F body pan on and had to modify it, but still hits the drag link when at the max turn position. Any info would be appreciated
Old 10-16-2017, 09:42 PM
69Camaro's Avatar
69Camaro 69Camaro is offline
I heard the Mast Motorsports pan fits with the Holley mounts and Ridetech Tru-Turn as well as the Holley pan. There are 2 Holley pans available so do some research for your application.
So far I have been very happy with the Holley swap components. I am mocking up a Mast Motorsports pan tonight and will report back.
1969 Camaro
Kore3 Z06 brakes
Hydratech hydroboost
Wilwood master
Ridetech stage 2 with truturn
Forgeline GA3 18x9.5/18x12.0
BFGoodrich Rivals 275/35 & 335/30
Magnum T56
Lots of AMD sheet metal
Sprinkled with DSE parts
Ididit Steering column
GM 376/525hp crate
Moser 12 bolt, tru-trac, 3.73:1
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 10-16-2017, 10:26 PM
Musclerodz's Avatar
champ pan ls1000
Mike Redpath
Musclerodz & Customz
facebook page
Old 10-17-2017, 06:16 AM
dhutton dhutton is offline
Mast Pan or Holley 302-2.
Old 10-17-2017, 08:12 AM
rickpaw rickpaw is offline
or Holley 302-3. It has the same dimensions as the 302-2, but has clearance for stroker cranks and turbo oil drain built in, just in case you want to add turbo down the road.
Tu Ho
Old 10-17-2017, 11:26 PM
69Camaro's Avatar
Good to know, I hadn’t heard of a 302-3. I bought the Mast pan specifically because of the stroker clearance.
I’m pleased to report that the Mast pan, Ridetech Tru-Turn and Holley swap kit all fit together perfectly with no modifications in my stock subframe.
I did need to cut a hole in the floor for the top 2 bellhousing to transmission bolts on the Magnum T56. But I could have used a BFH to gain the same amount of room.
1969 Camaro
Kore3 Z06 brakes
Wilwood master
Magnum T56
GM 376/525hp crate
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 10-22-2017, 08:14 AM
Thanks for all the feedback, will do my research.
Old 10-24-2017, 12:55 PM
jwcarguy jwcarguy is offline
Banned
I use the Mast pans, great fitment in stock subs / steering
Old 12-15-2017, 03:50 PM
BLO BY U - TA BLO BY U - TA is offline
My pan is a GM...still has the part number sticker on it.
I could take a picture of the part number if your interested.
I'm running a LQ9 btw
1955 Chevy Hardtop
1969 Camaro
1950 Chevy truck
1941 Willys
Old 01-22-2018, 01:49 AM
gnx7's Avatar
gnx7 gnx7 is offline
These are nicely baffled..... running one on my project
http://www.autokraft.org/products/
