Old 02-14-2020, 05:33 PM
Sonar Chief's Avatar
Default You all good to go!
Originally Posted by 214Chevelle View Post
I hope not. Currie built the rear end and I sent them the Miller Built kit as Jay said they've installed many of his kits. Can anyone else verify how this looks? Even if it is upside down, I still have to install the 3rd member, axles, etc. Plus, everything else is coming back off to get the chassis and rear end powder coated.
I can verify that the pic from Currie is correct for OEM installs. I did change mine from OEM install to get the brake caliper in front (lower CG when applying the brakes) and also keep the brake pull coming in from the front.
I swapped out brake sides basically and keep the pull lever on the top ... check out the pics here from my thread:
https://lateral-g.net/forums/showthr...34830&page=134
Old 02-14-2020, 08:12 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default Looks Great :)
You really cannot mount them wrong per say. This kit is VERY versatile and can be properly installed more than one way.
Calipers can be mounted rear/front of the wheel, as well as the e-brake cable approach above/below axle tube and all depending on what side/direction the MillerBuilt adaptor is mounted.
Sonar Chief took it a step further and has the caliper and e-brake cable approach on the same side.
All just depends on what works best for each particular application and possible variables.
The Following User Says Thank You to MillerBuilt For This Useful Post:
Sonar Chief (02-15-2020)
