Old 01-07-2008, 12:53 AM
blown71nova blown71nova is offline
Default Fs: New MSD #85551 Pro Billet Chevy V8 Distributor
FS: NEW MSD PRO BILLET CHEVY V8 DISTRIBUTOR
NEVER USED, NO BOX, & NO INSTRUCTIONS
Summit Racing Part # MSD-85551
Computer Controlled Compatible: No
Trigger Style: Magnetic
Advance Type: Mechanical
Cap Style: Male/HEI
Tach Drive: No
Slip Collar: No
Gear Material: Iron
Ignition Box Required: Yes
Distributor Rotor Rotation: Clockwise
Helix Rotation: Standard
Distributor Cap Color: Red
Housing Material: Billet aluminum
Housing Finish: Natural
Pro-Billet Chevrolet V8
This is our most popular performance distributor! The housing is machined from a billet of 6061-T6 aluminum on a state-of-the-art CNC machine producing exact tolerances. Modified blocks can also take advantage of the O-ring seals to help maintain proper pressure.
For high rpm stability, a .500" steel shaft is supported by a sealed ball bearing and a long sintered bushing. This shaft also receives a QPQ coating for friction reduction and resistance to corrosion. A precision machined reluctor is attached to the shaft which triggers the magnetic pickup mounted in the housing.
This high output magnetic pickup is the most accurate way to trigger your ignition. Plus, with no moving parts to wear or adjust, the pickup is maintenance-free! Just above the pickup is MSD's adjustable mechanical advance assembly. Different springs and stop bushings are supplied so you can tune an advance curve to match your application.
NOTE: Must be used with an MSD 6, 7, 8 or 10 Series Ignition. Supplied with a Cap and Rotor.
COMES AS SHOWN
Costs $260 Shipped New From Summit Racing
My Loss Is Your Gain
$190 Shipped
