Old 11-11-2012, 06:29 AM
cheezer cheezer is offline
Default Ignition wires touching headers on LS
Hello,
I have just finished installing an LS engine in my Camaro and I see that a couple of the ignition wires are touching my Stainless Works headers (for stock subframe and steering box). Do any of you people have any ideas or solutions to this problem ?
cheezer
Old 11-11-2012, 08:38 AM
Sieg's Avatar
Sieg Sieg is offline
Without pictures about all anyone can suggest is route them in a manner that doesn't contact the header. Not enough information.
Old 11-11-2012, 09:41 AM
I was just wondering if this was a common problem with that combo.
Pictures will be forthcoming on Monday.
thanks,
cheezer
Old 11-12-2012, 05:19 PM
Default Pictures
Here are some pictures of the problem. As you can see, some of the wires are a little too close for comfort for my liking.
Any ideas, other than another set of headers, would be appreciated.
Thanks,
cheezer
Driver side
passenger side
Old 11-12-2012, 05:52 PM
camcojb camcojb is online now
I used aftermarket wires with 90 degree plug boots. They have a lot more room than the factory wires do.
Old 11-12-2012, 06:48 PM
yep, I believe there is a brand that has a reflective coating on it too.
Old 11-12-2012, 10:23 PM
Sieg's Avatar
cheezer - These answers are along the lines I was thinking. Non-OEM custom addembled possibly with high qualitythermal sleeves.
Old 11-12-2012, 11:27 PM
intocarss's Avatar
http://www.heatshieldproducts.com/pr...sul_boot/70/20
Old 11-13-2012, 12:40 AM
rocketrod rocketrod is offline
I have the re-designed SW headers and I used BWD Select - Spark Plug Wire Set
Part Number: CH7875 from O'Rielly's
They have a lifetime warranty and all the wires clear except #5, which I wrapped with a Taylor heat shield (similar to the INSUL-BOOT in the previous post).
Rod
1969 Camaro - LS2/4L70E
Old 11-13-2012, 09:18 AM
Default Thanks
Thanks for the quick responses
No O'Rielly's in Canada, but I have cross referenced part numbers at NAPA before.
As far as brands, do the boots on the MSD wires bend like they say? The product literature says straight boots, but on their site the say "bend to fit". Is this so ?
cheezer
