Old 11-03-2014, 08:54 AM
TBM Brakes's Avatar
TBM Brakes TBM Brakes is offline
Default Proper Brake Pedal Ratios
We're new here, so we're just going to share some info with you guys without pushing any particular product. We hope you like it!! If you have questions, post them up. We'd be happy to help!!
Brake Pedal Ratios
In order to have the best brakes possible, it is absolutely necessary to combine the ideal pedal ratio with the proper bore size master cylinders. Whether you are using a single master cylinder, or dual master cylinders on a balance bar, the basic following concepts apply: More here...........http://www.tbmbrakes.com/brake_pedal_ratios
Old 12-29-2015, 11:36 AM
TBM Brakes's Avatar
As you're looking at your brake system during the off season, let us know if you have any questions. We'd be happy to help!
Old 06-08-2017, 01:58 AM
manny z manny z is offline
Default Brakes
If you guys are still around, I have a few questions..
Old 06-08-2017, 03:19 PM
TBM Brakes's Avatar
We're here!! can you give us a call at 1-805-987-7867?
Old 06-09-2017, 02:47 PM
Yukon Cornelius Yukon Cornelius is offline
Your link in the first post is dead.
Old 06-10-2017, 01:14 PM
speed_m5 speed_m5 is offline
I went 7-1 worked out very well for me
