Old 07-23-2017, 10:03 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Default LS2 T56 LS7 Clutch
Does the LS7 clutch/flywheel setup work on a LS2? Want to make sure before I pull the pin.
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 07-24-2017, 03:39 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I believe you will want the ls2 flywheel with ls7 clutch. I seem to remember a difference in the hub area in the ls7 flywheel. The clutch will def work.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 07-24-2017, 07:49 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
you need the ls7 flywheel with ls7 clutch, or ls3 flywheel. ls1/2/6 flywheel will not work with ls3/7 clutch. for it to work on your ls2 engine, just get a matched set of ls3/ls7 clutch and flywheel
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 07-28-2017, 12:39 PM
andrewb70's Avatar
LS2 and LS7 flywheels are the same (LUK LFW191). It is easy to tell them apart from the LS1/LS6 flywheels. The former have raised pedestals where the pressure plate bolts to, while the latter flywheels are flat. The crank bolt patterns are the same.
Andrew
