What the consensus on thermal protection for the floor. I have already put Dynamat Extreme on for sound deadening. Now I need to move on to heat insulation since the headers and exhaust are tucked up within 1/2" - 1" of the floor.
That's a lot of components. Is there a 60s-70s Camaro or Firebird build on here with the stuff that sticks to the bottom of the car? I'd like to see how it holds up.
I have that stuck to the bottom of a customers 69 Camaro for nearly 5 years now.....still there. Have had the trans out a couple of times in it wasn't sagging anywhere.
I use that with DEI UnderCarpet lite and it works pretty well.
I used a bunch of the DEI heat shield on my fire wall, transmission tunnel and fuel tank. Good stuff. Has held up well for almost 4 years. I used the tape they sell to seal the edges and seam. It looks very OEM and does a good job of keeping the heat out.
That does look like a nice product however it installs on the Exterior. I wouldn't want to see that on my firewall. If I used it, I would do the trans tunnel. Kinda out of sight. Just my .02
69 Camaro Convertible (LS3/TKO in the works)
I used a second skin audio product. Heat wave maybe? Worked like a champ. My right heel used to get hot through my shoe from the collector and it totally cured that. Foil on both sides, jute-like material in the middle.
