Old 07-11-2018, 09:57 AM
Originally Posted by DBasher View Post
For the Jeep or Toyota, Uncle Rico?
Lance, looks like a great opportunity to install some V bands on the exhaust, you know you’ll be back in there at some point.
Time will tell... Father son project is on my horizon.
Old 07-11-2018, 09:59 AM
SSLance's Avatar
SSLance SSLance is offline
These are a 3 ton version and the base is a bit bigger 7.1" x 7.1" with a lowest height of 9.5"
https://www.gmdesolutions.com/item-d...type=equipment
Like Greg said, I would always back these up with the rolling chassis jack up near the middle of the car like in the pics above. Between the two the car is VERY steady on the lift as is.
These frames just aren't stiff enough to lift the whole back (or front) of the car from the middle like your average tube frame race car...
Lance
Old 07-12-2018, 02:53 PM
camcojb camcojb is online now
Y
That would be a 4" jump up on the whole jack assembly, pretty sure the pads wouldn't go under the frame at their lowest point then. Interesting out of the box thought though.
I don't know that it's out of the box thinking, I think it's supposed to be on top lol. That way you can extend the arms even with it all the way down. Mine is only 3 1/4" above the rails with the pads on. If your frame is that low then you're a lot lower than I am or any car I've had on my lift.
NEVER MIND.... looks like your jack is different than mine.
Old 07-12-2018, 05:48 PM
One of you is #upsidedownandbackward
LOL
Old 07-12-2018, 06:33 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
13" - 21" tall
Most stands (including mine) start at about 15" high
I have a set of four of these. They're very nice and 3 points do make a plane, not that you are on an uneven surface, but they are very stable.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
