Old 08-16-2017, 02:26 PM
kabinet kabinet is offline
Default Wiring 2 sources (engine and AC) to one cooling fan
I'm trying to wire the AC to the engine cooling fan. Power from the engine is coming from ECM. It is fused and relayed. The power for the AC is coming from a relay grounded by a trinary switch. Here is a diagram of what I have going on. Can I just plug both wires into the fan or is that bad? If one system is powered and the electricity will flow back to the other system and that one also turns on will it do something crazy? I basically want to know if I can take the "?" from my diagram and connect it to the purple. Thank you!
Old 08-16-2017, 06:45 PM
dhutton dhutton is offline
You can just connect both wires to the fan. I have done it that way no problem. Red ECM wire to purple wire.
Old 08-17-2017, 04:43 PM
Thanks, Don!
Old 08-18-2017, 08:34 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
I would just connect the ECM feed to the 87A pole on the A/C relay.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 08-18-2017, 02:57 PM
I think you get some redundancy and a slight improvement in reliability when you connect the relays in parallel as I suggested rather than connecting them in series.
