Old 08-08-2017, 03:06 PM
DT69Cam DT69Cam is offline
Default Holley accessory drive LS3
Did you guys have to trim 1/8 of an inch of the water pump bosses (LS3 crate engine)as the Holley directions suggest for the accessory drive set-up ??
69 Camaro Convertible (LS3/TKO in the works)
Old 08-09-2017, 07:53 AM
TomM's Avatar
TomM TomM is offline
I used the Holley full accessory set up on one engine and it kept throwing the belt. This was an LS3 connect and cruise package. I had to do some trimming to the tensioner attachment on the water pump. I think that's what I had to do but cannot remember specifically....
At best, check your belt alignment carefully with a straight edge, I know there was an alignment issue.
T,
Old 08-10-2017, 03:58 PM
T,
Thx Tom!
