Old 08-10-2016, 12:36 PM
TomM's Avatar
TomM TomM is offline
Originally Posted by Carlsson View Post
Do you know if this will work in a f body 67? Does it have room to have the alternator placed like that? If so it looks like the kit I will get!
Asked the tech support at pace p. also and they would get back.
Don't know about a 67, but the only thing that might cause a problem would be steering box interference.....but I think the alternator is tucked in enough. Used the same thing on 63-67 Chevy 2 Novas with stock clip and it all cleared....
T,
Old 08-10-2016, 01:15 PM
Carlsson Carlsson is offline
T,
Well it maybe work then? The nova is similar in the front as far as I know? Without being an expert... Would look good to have it down there.
Pace p. Recommended this
http://paceperformance.com/i-6485405...7-engines.html
Good price!
But if there possible to hide the alternator I will go with that. Maybe more easier to se when the engine is in the subframe.
Tattoo artist from Sweden with interest in old cars.
Instagram @tattoosoder
Old 08-10-2016, 02:32 PM
Or maybe it is the 68-72 nova that is the same...
Old 08-10-2016, 03:27 PM
TomM's Avatar
68-72 Nova is almost same as Camaro, 62-67 are completely different. The accessories Pace recommends are essentially Corvette, much like the Holley..
T,
Old 08-10-2016, 03:59 PM
rallystyle rallystyle is offline
yes you can use the holley setup in a first gen camaro no problem. if your using it for the p/s alt you will need to use the smaller p/s pulley to clear your upper control arm. you can find the info and part # by looking at the install instructions.
1970 El camino
1969 camaro
1996 civic
Old 08-10-2016, 05:27 PM
130fe 130fe is offline
Thumbs up
Good price!
You can use either the kit (listed above that mounts the Alternator high) from Pace or the Holley kit. The only difference is the Holley kit uses the truck style alternator. The Pace kit is great for the price. The Holley kit is nice because it is one stop shopping. I have the Pace one in my 68 and a local buddy with the Holley one in his 69. Plenty of clearance using the stock PS pulley that comes with the kit. Won't go wrong with either one. If you add AC, the Holley AC bracket (like Samckitt shows) is the same exact setup I have in my car.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 08-11-2016, 12:36 AM
130fe:
Thanks for that answer!
Old 09-02-2017, 01:40 PM
colorado80439 colorado80439 is offline
Drive Junky
Old 09-05-2017, 12:45 PM
BMR Sales's Avatar
Originally Posted by colorado80439 View Post
Drive Junky
That's what I just put on my LS3 in my '73 Camaro - a Piece of Artwork! Great Guys to deal with - I've got a problem with my Reservoir hitting my Steering Box but they are making it right
Old 09-07-2017, 05:59 AM
68LS1's Avatar
68LS1 68LS1 is offline
Drive Junky
This
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
