Old 10-08-2016, 09:14 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default NEW - Moser 7900 - "Bolt-On" C6/C7 Hybrid Floater
Full Floater System -
Installs onto any Rear-End that utilizes the Moser 7900 / Strange H1143 Style Ends.
The Moser 7900 / Strange H1143 Style End is very similar to the Big Bearing Ford End since it also has a 3.150" bearing bore, however this Style Hybrid End has the GM (small car) brake flange bolt pattern. If you have this style end you are now able to bolt on a Full Floater...
That's right,,,, you can use your current rear-end housing, NO welding & simple installation. BOLT-ON!
Advantages:
  • Bolts to your Moser 7900 /Strange H1143 Style Housing End (Chevy 10/12 bolt application now available!
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th/6TH Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th/6th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications has a negative 1/8″ wheel mount surface per side (based on an existing 2.810″ axle/brake offset)
Fitment: Any rear-end housings that utilizes the Moser #7900/Strange #H1143 Style Housing Ends
Hybrid Bolt-On “Full Floater Kit” (pictured below)
E-brake Assemblies & E-brake Cable Brackets NOW INCLUDED With Each Floater Kit
Hybrid Bolt-On “Full Floater Kit” (pictured above)
Full Floater Kit Includes:
• (2) Billet Steel Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) SKF 33 Spline Hub Assemblies
• (2) E-brake Assemblies
• (2) E-brake Cable Brackets
• (1) Install Kit
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICING AT - https://millerbuiltusa.com/hybrid-fl...ms/moser-7900/
Have interest?
Have questions?
Need more info?
Distributor Inquires Welcome!
Old 10-17-2016, 09:34 PM
Default Assembled Pics - Moser 7900 Base Kit
Assembled Hybrid "Full Floater Kit" with C5/C6 E-brake Kit
*Housing Ends for display purpose only - not included...
Old 06-05-2017, 08:17 PM
Default In stock
In Stock
Old 09-02-2017, 08:21 PM
Default In Stock
In Stock!
Old 12-18-2017, 08:34 PM
Default Get Yours
In Stock!
Old 08-12-2018, 12:25 PM
Default Get Yours
In Stock!
Old 08-15-2019, 10:17 PM
Thumbs up Solutions
Advantages:
• (1) Install Kit
Have interest?
Have questions?
Need more info?
