11-19-2016, 06:17 PM
LS7 crank, rebushed Ti LS7 rods
Item Location (City/State): San Ramon, CA
Price: $450
Description:
LS7 factory dry sump crank polished with .010/.010" undercut journals. (less than the thickness of a horse hair)
$450
LS7 Ti factory rods rebushed with Katech bushings, new ARP 2000 rod bolts
$1200
I will only sell the rods if you purchase an LS7 crank from me and vice versa. I have used non Ti rods with an LS7 crank before and the mallory needed to balance the crank is $300+ on top of balancing. So you should really run Ti rods with them.
** You can run the dry sump crank as a wet sump style system with a couple inexpensive parts (and non dry sump style oil pump).**
Shipping is additional (approx $60-80 for the crank depending upon location. I will cover the shipping on the rods to the lower 48 states.
I can get custom RaceTec/AutoTec pistons in just about any custom size for about $1K with rings. Takes 3-4 weeks to make them.
11-27-2016, 08:27 PM
was out of town for a week. Replied to PM's
Thx
12-05-2016, 11:34 AM
To the top!
12-08-2016, 04:11 PM
Dropped the price on both cranks....
I can't believe nobody has bought the crank and rods when they are sooo superior to Callies Compstar crank/rods in every aspect at the same price and certainly better than any other Chinese sourced steel forged crank/rod!
These rods are STUPID light!
A stock LS7 longblock with the exception of a cam/valvesprings with a small ECS1500 supercharger recently went 9.05@159mph..... http://www.corvetteforum.com/forums/...m-end-ls7.html
Somebody please build themselves a bad ass little setup. Do an LS3 block, this rotating assembly and Dart Pro1 LS3 heads (370cfm/$2400 per pair) for an easy 625hp+ 416ci 11:1 pump gas friendly setup.
http://www.enginelabs.com/engine-tec...ead-from-dart/
12-14-2016, 12:17 PM
to the top
12-29-2016, 01:04 AM
to the top..... Add an LS3 block and you have a sweet 416 setup.... either keep it wet or dry sump!
01-05-2017, 08:48 PM
to the top!
This will work in ANY LSx block with custom pistons.... which I can help with supplying. Titanium rods!
01-16-2017, 01:27 PM
Monday bump
01-26-2017, 03:15 AM
to the top!
02-01-2017, 10:59 AM
to the top
