Item Location (City/State): Las Vegas
Price: 395
Description:
I have a new Ron Francis brand Express 20 circuit/ 16 fuse Vehicle Wiring Harness kit form Classic Industries
Classic Industries part# BW900214 listed as both Universal application and 67-9 F-body
https://www.classicindustries.com/pr.../bw900214.html
Ron Francis # 328435 / XP-768
This kit is "new", but was mocked up (started install) in vehicle that we purchased (68 Camaro) that the project has changed directions
Description on website:
This express wiring harness set from Ron Francis Wiring is built specifically for 1967-69 Camaro and Firebird models.
The wiring includes the complete car, covering the starter, alternator and most stock GM, Ididit, Flaming River and other brand s of steering columns. It will wire full gauge sets including tach; address HEI, points and aftermarket distributors, neutral safety switches, all lighting needed for most safety inspections including high and low beams, indicator lights, parking, turn si gnal, brake and third brake light.
The panel readily accepts fuel injection. Uses high temperature fire resistant, color-coded wire with the circuit clearly and legibly printed. A quality headlight switch with wiring is included, as well as an i solated cooling fan relay. Includes color coded instructions. A unique serial number for each kit enables Ron Francis to technically support the installation to you or any subsequent owner.
Made in USA
Features Include:
Clear Coated, Polished Stainless Steel Finish
20 Circuits on 16 Fuses
4 Select-A-Circuits
Faster Installation with New Style Term inal Block
Cooling Fan Relay Included
Only the Best Quality Wire and Terminals
Proper Size Heavy Wire for Each Circuit
Handles 100 Amp or higher Alternators
Serial Number
Includes the Proper C onnectors and Terminals
Clear, Simple, Color Coded Instructions
We were going to keep for a future street hot rod / Willys truck install , but need funds for build
Asking $395 shipped
SOLD!!
pm/ call/ text (702)677-4085
