Go Back   Lateral-g Forums > Technical Discussions > EFI and Forced Induction
Old 01-25-2009, 03:50 PM
groovyjay's Avatar
groovyjay groovyjay is offline
Default Barry Grant LSx Cross-Ram?
If my memory serves me right, there was some hype about BG coming out with a cross-ram style EFI manifold for the LSX motors. Has anyone anything on this? Any news?
Old 01-27-2009, 10:31 AM
ss dave ss dave is offline
Don't know about BG but Beck makes a beautiful cross-ram.
However, all my research into sheet metal manifolds for the LSx has been somewhat disappointing. None have matched the Fast in performance for the LS1/2. And that's a non-ported manifold.
The LS7 can be improved with porting, Tony Mamo @ AFR is doing mine this month.
The sheet metals are all heat sinks as opposed to stock.
Several companies and individuals are working on the problem. See LS1tech.com for updates.
Old 01-27-2009, 10:01 PM
you really don't need/shouldn't use a sheet manifold intake on an LSx unless you are building either a very large motor or running very high boost levels that require the use of a 100+mm throttle body. There are too many other choices that work great. You've got carb style intakes and ported plastic ones. FAST will have a new intake coming out in a few months for the L92/LS3 that should prove to be great. These engines also don't need that much air if you drive it on the street. A 95mm throttle body is the max you want to use for a street car and those are reserved for the stroker motors pushing 420 cu in plus. Anything larger has bad off idle/off throttle characteristics and is sluggish. It'll only like WOT, nothing in between. You size the manifold accordingly and it becomes obvious the flow potential of a sheet metal one is not needed. People often lose track of air velocity in search of pure volume which leads them to believe bigger is better. Velocity must be maintained.
This new FAST manifold is designed to work with either a 90 or 92 to 102 mm throttle body. It should easily support any stroker motor designed for street driving.
Oh and no, I've heard nothing about this BG intake. Sorry to not stay on topic
Old 02-02-2009, 03:58 PM
groovyjay's Avatar
Picture of the unit:
Anyone got any more information?
Old 02-02-2009, 05:53 PM
ironworks's Avatar
WOW that's nice looking
Rodger
Old 02-02-2009, 08:11 PM
The WidowMaker's Avatar
The WidowMaker The WidowMaker is offline
$$$$$$$$$damn$$$$$$ that thing is sweet
"The WidowMaker"
70 Chevelle Pro Touring - Garage Built, Backyard Painted
Custom 4 Link & Watts, Rushforth Wheels, Ats Spindles, McLeod RXT Twin Clutch, T56 Magnum, C6Z Calipers & Ring Bros Hinges
Special Thanks To: Rushforth Wheels ; Kore3 ; SC&C
Build Thread : https://lateral-g.net/forums/show...ght=widowmaker
Old 02-04-2009, 12:23 PM
Pantera EFI Pantera EFI is offline
Default LS-1/2 "Cross Ram"
Dynatek Racing is making a "cross ram" for a 1960 Corvette, with their 48IDF EFI throttle bodies.
This is made to fit the LS-1/2 head.
Their TBI's have the electronic injectors hidden inside the casting.
Old 02-05-2009, 01:41 AM
Bowtieracing Bowtieracing is offline
Would like to hear more about it!
Can this really be true : ( found on Dynateks web site )
No programming or dyno tuning required
Self-learning computer system automatically defines fuel tables
63 Z06
Old 02-05-2009, 06:33 AM
That Barry Grant unit looks nice
Old 02-10-2009, 04:42 AM
groovyjay's Avatar
I'd also like to learn more about the Dynatek set up!!!
