Old 07-17-2019, 10:02 AM
VTtransam VTtransam is offline
I went with 295s on 10.5" wide 18" diameter rims, 8.25" back spacing. Guessing at the suspension set-up, I went auto crossing for the first time this past weekend. No rubbing or anything with the 295s. 315's would be tight but I think I'll try them next!
Old 07-26-2019, 01:25 PM
Blake Foster's Avatar
Originally Posted by alongfortheride View Post
! they are not a "BOLT IN" they are made to fit with some modifications.
Made to fit with some modification. Just like all your parts. True story there.
You sound upset???
Your saying the fender lip area was more work to make fit than reworking the stock inner? I doubt that. But not here to argue.
The inner was designed to come out to the inside of the fender and drop straight down so you get the maximum space possible for compression travel under braking. The inner lip needs to be worked to provide more clearance with a 315 tire for sure but hey you don't have to widen the fender!!
sorry you were not happy with the product we have not had any other negative comments.
Blake Foster
www.speedtechperformance.com
Old 07-11-2021, 12:06 PM
holschen's Avatar
holschen holschen is offline
im sorry blake i would never recomend anyone buying anything from you before getting a waranty i fit properly before. if i buy something for alot of money , i expect it to fit . i have pics to show. but it would be better if you put up pics and explained what minor works means.
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 07-12-2021, 09:30 AM
alongfortheride alongfortheride is offline
Here come the truth. Vendors build stuff. It all looks good till it meets the real world. For the cost of these parts they should fit. All about the dollar. Nothing about quality.
Old 07-12-2021, 02:01 PM
camcojb camcojb is online now
I'm not sure Blake reads this forum anymore, probably best to contact him directly.
Old 08-03-2021, 01:40 PM
Build-It-Break-it's Avatar
Speedtech has a video up about their inner fenders.
I talked to Blake about them right when they came out for the extreme frame but ended up building my own.
Ahmad B
