Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Ron Sutton Race Technology - Suspension, Brakes, Safety, Aero, Powertrain & More
Old 06-13-2018, 06:58 PM
Ron Sutton's Avatar
Car Year & Model: 70 Ford Mustang Fastback
Competing in: Track Car & Occasional NASA TTU races
Front Clip/Suspension: GT Track-Warrior
Rear Clip/Suspension: GT Track-Warrior
Engine: Track-Warrior 3 LS7 700 HP
Trans: PPG Sequential Shift T56 6-Speed
Brakes: StopTech 14 ST60/ST40
Owner: Greg Weld
Builder: Randy Chastain One Off Customs
More updates & photos ...
Most of the stuff is straight out of our "Build-Your-Own Track-Car Catalog" HERE
The RSRT Track-Warrior 3 LS7 built by SDPC Race Shop - Details HERE
PPG Sequential T56 6-speed Trans, built by Joe Dederichs - Details HERE
QuarterMaster Optimum RR Clutch with 2 "Rally" Discs for easier take off - Details HERE
A shot today before Body was removed ... to get an idea of tire width & track width.
Wheels are 18x13 Forgeline GZ3R. 10" backspacing in front.
This is a "Zero Scrub" car. Turns like a mutha in the tight corners.
Good look at the wheels, Track-Star hubs & StopTech Trophy brakes Optimized by Ron Sutton
Front End mount photos
Door Hinges
With Body Removed to finish the door X-brace bars
Car is Super low to ground, as you can see.
In fairness, this fella is 6' 1" / Actual roof height is 47"
Old 06-14-2018, 08:05 AM
tx71nova's Avatar
tx71nova tx71nova is offline
Attachment 65886
Originally Posted by Ron Sutton View Post
5 out of 6!
Yes, #6 is tricky.
Seems like #6 has disappeared....Tricky
The Following User Says Thank You to tx71nova For This Useful Post:
camcojb (06-14-2018)
  #73
Old 06-14-2018, 10:16 AM
SSLance's Avatar
SSLance SSLance is offline
lol... Busted!!!!
Lance
Old 06-14-2018, 04:37 PM
Ron Sutton's Avatar
Originally Posted by tx71nova View Post
Attachment 65886
Haha. See! I told you #6 in the contest was tricky.
All it was .. was a spare adjustment knob sitting there. I figured it would make for some funny guesses.
Old 06-14-2018, 06:33 PM
Ron Sutton's Avatar
Howdy everyone!
Our client Ron Ver Mulm installed one of our GT Decoupled 3-Links in his autocross car recently & used his GoPro to capture the first runs. After watching the video, it was easy for me to know the rebound valving & spring rate are spot on, but his application needs stiffer compression valving & a taller, softer & more progressive bump stop. He ran his fastest runs ever with our new GT Decoupled 3-Link, over his conventional 3-link. After we change the compression valving & bump stop, he'll most likely shave another .3-.4 off his lap times.
For those not in the know ... the decoupled 3-link is the highest grip, fastest rear suspension available period. The shock version won so many Trans Am races back in the day, they outlawed it. (You can run our TA version legally in Trans Am, which uses poly bushings & no shock.)
We utilize this "shock controlled" decoupled 3-Link rear suspension in all of our GT Track-Warrior cars featured in this thread.
* Greg Weld's 70 Mustang
* Mark Milliron's 69 Torino
* Scott Pomeroy's 68 Chevelle
* Robert Taylor's 47 REO Speedwagon Truck
* Many others
Got questions? Want one for your autocross or track car?
See both versions in our catalog HERE
Contact Dave at 844-722-3832 Ext 3
Or email, Dave@RonSuttonRaceTechnology.com
Old 06-15-2018, 07:58 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is online now
I assume your talking about the the bump stop on the upper link? What are you looking for when you want it to be taller, the bushing to be in contact during full travel? Just want to understand how this works (since I have one!) and what your seeing that the video shows.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 06-15-2018, 08:36 AM
Ron Sutton's Avatar
Hey Craig!
In this fella's autocross application, the "actions" of the Decoupled 3-Link happen in shorter time frames. Add in the abrupt on/off throttle driving style ... and yes, he would benefit from a taller, softer bump stop to be in contact during full travel. Under hard acceleration, when the top link bracket of the housing is pulled all the way back, we'd be OK with a small gap, or just barely squeezing a very soft (low spring rate) bump stop. Then as the driver lifts & brakes, and the top link bracket of the housing falls forward, a taller, softer bump stop would control it sooner & slow the decel link compression.
We don't need that for road courses, where the "actions" of the Decoupled 3-Link happen over longer time frames. What he has here, as do you, is our setup optimum for road courses. We want the top link bracket of the housing to move freely under acceleration with no additional spring rate on the links, until we lift & brake on corner entry.
Old 06-15-2018, 09:09 AM
Hey Craig!
Got it, thank you. So would it be beneficial to have both, and swap out bushings depending on whether its road course or AutoX?
Craig Scholl
CJD Automotive, LLC
Old 06-15-2018, 01:35 PM
Ron Sutton's Avatar
Yes ... to a degree. If you wanted to optimize every tenth of a second lap times, I'd have two setups. If not, and you're planning to both autocross & road race (or track) the car ... we should lean towards the middle.
Old 06-15-2018, 02:32 PM
Ron Sutton's Avatar
Contest Winners!
Ahmad - Build-it-break-it
Nathan - Tx71Nova
PM me with your shirt size & address.
Correct Answers:
1. Air Jax Wand
2. Battery Charging/Jumping Terminals
3. Decel Link Shock Reservoir gas schrader valve
4. Accel Link angle adjuster
5. Fire Suppression line - Leading to driver footwell
6. A spare adjuster cone .. just sitting there ... for no reason.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
