Would you be ok grinding....
Down the edges of your stock tail light lenses or your $500 billet lenses to fit into the tail lamp housings? I'm not talking much, like 2mm, 1mm per side or so. My caliper says stock lenses are almost exactly 2mm wider than than Marquez billet lenses.
I'm working on something and I built it off my Marques billet tail lamps. When I checked it to repop lenses they are just a touch to big and would need to be run across a belt sander to fit like they should.
So would you have a problem grinding the edges on your lenses? It will never been seen and carbon fiber would be covering it up.
