Old 11-04-2009, 08:20 AM
cwylie cwylie is offline
Default 17 inch torque thrust
Whats the biggest brake you can run? I want to go bigger but don't want to buy new wheels just yet.
Old 11-04-2009, 12:18 PM
Apogee Apogee is offline
A true C5/C6 kit like we sell won't fit inside 17" TTII's without a wheel spacer to gain clearance between the corner of the caliper and the wheel.
Touring Classics makes their "Hybrid" C5 brake kits that utilizes the 13" x 1.1" C4 HD rotor and C5 PBR 2-piston caliper. The C4 rotor has a deeper offset which gives adequate clearance for the 17" TTII's. You can download their wheel fitment templates from their website to confirm fitment.
CPP's kit will probably fit as well since they manufacture their own rotor and it looks very similar to the 13" C4 rotor...but apparently is not the same.
Tobin
KORE3
www.kore3.com
Old 11-04-2009, 12:56 PM
Would like a 13 inch wilwood kit fit?
Old 11-04-2009, 02:09 PM
Possibly. I'd suggest pinging Prodigy as I'm sure they could answer that for you.
Tobin
KORE3
www.kore3.com
Old 11-04-2009, 07:00 PM
markd's Avatar
markd markd is offline
Yes – they will work! I did have 13” Wilwoods upfront w/ 17” Torque Thrust wheels. Below are some pics. I have since switched to 14” brakes and 18” wheels.
Hope this helps,
Mark
Project 69 Camaro: DSE mini tubs, Chassisworks G-Bar and FAB-9 rear suspension, Chassisworks front sub-frame, 14” Wilwood brakes with 6 piston red calipers, 18" Fesler 905 Wheels, Fesler Billet, ISIS multiplier system, Vintage Air, Prodigy Cool Package, Ricks Tank, Turnkey LS3, 4L65e transmission and a lot of other cool stuff!
More pictures: http://camaro69vn10.com The Website is finally Updated!
https://lateral-g.net/forums/showthread.php4?t=13756
Old 06-19-2018, 02:59 PM
GeneWJr GeneWJr is offline
Hope this helps,
Mark
Mark,
Which Wilwood kit is this? Part #
Old 06-21-2018, 12:28 AM
USAZR1's Avatar
USAZR1 USAZR1 is offline
Mark hasn't been back to the site, in almost 6yrs. What are you trying to accomplish, Gene?
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
