Old 02-20-2019, 10:10 AM
NickBurns NickBurns is offline
Default TR6060 MG9 transmission mount and Crossmember
Hey folks - I’ve been searching high and low for some possible combinations to work with a Detroit Speed subframe. Seems no one makes a kit that works with confidence. The MG9 TR6060 (2015) mount bolts up to the side of the transmission. Does anyone know of a combination that works well with the Detroit subframe? I have the Detroit engine mounts with standard setback.
Nick's son was last seen finishing up his 1968 Pro Touring Camaro
1968 Pro touring Camaro
ALL DSE Suspension
2017 6.2L made of steel balls
Old 02-20-2019, 11:14 AM
Maybe I'm misunderstanding the question. Are you looking for a crossmember that works with the DSE frame for a TR6060?
I dont know specifically for the 6060, but my T56 Magnum works well on the hooker blackheart crossmember in my DSE frame.
PART# 12626HKR
Can see it a bit in this pic (old pic so can get more recent if you'd like).
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
2018 GMC Denali HD
Old 02-20-2019, 07:49 PM
Thank you for the reply but the TR6060 is longer and the mount actually attaches to the sides. This has become the issue. I wish I knew for sure that I could use this cross member since I have the headers . I may have to purchase it and do some fabbing. I thought for sure someone would of solved this issue by now.
ALL DSE Suspension
Old 02-20-2019, 08:14 PM
Is something like this an option?
http://www.brphotrods.com/products/T...etc/index.html
Texas A&M BSME 2008
2018 GMC Denali HD
Old 02-20-2019, 08:18 PM
Originally Posted by will69camaro View Post
Hmm now I am confused - I did order the CNC spacer from these guys but when I received the transmission I realized the bracket attached to the two sides? Maybe I was sold a standard TR6060 transmission not the MG9? I asked and made sure they said it was a MG9
ALL DSE Suspension
Old 02-20-2019, 08:59 PM
To be fair i'm not familiar with the differences. But i bet you can find something.
Texas A&M BSME 2008
2018 GMC Denali HD
Old 02-26-2019, 10:02 AM
Hey Will - I figured it all out. The motor and transmission came from Australia so it’s actually a Holden LSA 6.2. Basically everything is the same as the ZL1 LSA including the hood. I called TREMEC and they were able to confirm the transmission cross referenced a MG9 with the same guts and gears. I do have to fabricate something on the crossmember. I went with the hooker blackheart that fits my DS subframe and I will just have to get crafty with my welder .
ALL DSE Suspension
The Following User Says Thank You to NickBurns For This Useful Post:
will69camaro (02-26-2019)
Old 01-24-2020, 01:02 AM
Pete68's Avatar
Pete68 Pete68 is offline
Do all 6060's mount from the side?
1968 Camaro
2003 Boxster S
http://www.cardomain.com/ride/2543199
Old 01-28-2020, 10:38 PM
billohio billohio is offline
Here are the 2 mounts I have found showing the difference. What is weird, I have a LSA and 6060 out of a 14 zl1 and I haven't taken the crossmember off yet but I swear it doesnt look like the mg9 on the right
Old 03-22-2020, 09:14 PM
Thank you ! Yep very odd. I ended up buying the mount cut it apart and made my own! Much better than the one I bought !
ALL DSE Suspension
