Old 06-03-2020, 05:22 PM
Kmelander Kmelander is offline
Default Passenger Cowl Rust Repair
Repaired a section of rust-through on the passenger cowl.
Old 06-04-2020, 07:43 AM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
Isnt rust wonderful ? One of the "fun"things about Fisher bodies .But its nice that to be taken care of. Very nice work though. Good luck to you.
Old 06-08-2020, 12:27 AM
Beaded the cowl filler and worked up the courage to bead the rear firewall pieces.
The Following User Says Thank You to Kmelander For This Useful Post:
syborg tt (10-25-2020)
  #24
Old 09-13-2020, 10:19 AM
3 month update:
Tackled the front wiper cowl area. Painted, seam sealed, second skin. Welded it back together.
  #25
Old 09-13-2020, 11:07 AM
Fuel cell support cage and mocking into car. All pictures are “top mount” mock up. Going to try bottom mount to see how that looks. It will drop by 5”. Im speculating that will be better for handling but puts it down in the weeds and makes exhaust routing more challenging.
The Following 2 Users Say Thank You to Kmelander For This Useful Post:
camcojb (09-13-2020), syborg tt (10-25-2020)
  #26
Old 09-13-2020, 02:04 PM
ScotI ScotI is offline
That tank placement looks good visually. Not too high or engulfing majority of the trunk space & not hanging too low.
Kmelander (09-13-2020)
  #27
Old 09-13-2020, 06:22 PM
Yeah, I went with that height. Tacked it in and started making the mounts today.
  #28
Old 09-15-2020, 09:45 PM
Got the mounts on it, took it out of the car and welded it up.
  #29
Old 09-17-2020, 07:32 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Don't see many post 72 Novas getting this kind of love! - I like to see someone else using the GM 8.5" rear ends - I like them, They are the Rodney Dangerfield of rear ends
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
The Following User Says Thank You to ZMAN1969 For This Useful Post:
Kmelander (09-17-2020)
  #30
Old 09-17-2020, 04:17 PM
F'in mine's Avatar
Zman, this ones for you. I'm building a 8.5" that I picked up for 150.00 with the posi from a 71 Camaro. Had it shortened properly, gonna add a bunch of upgrades, 1350 pinion yoke, strange axles and Moser 7900FM ends with LS1 rear brakes.
https://www.ebay.com/itm/Chevy-GM-8-...53.m1438.l2649
It's part of my reverse LS build, accumulate, prep as much as can in advance before I pull the SBC & Muncie.
1969 Camaro SSRS
Simon
The Following User Says Thank You to F'in mine For This Useful Post:
