Go Back   Lateral-g Forums > Technical Discussions > How To's, Tips, and Tricks
Old 08-16-2017, 06:37 PM
traut811 traut811 is offline
Default Mini tub tire sidewall clearance on 69 camaro?
It's time I get back on the camaro build. I'm going over the car trying to remember where I left off over a year ago.
Then I remembered....
My sidewall to inner wheel well clearance seems tight.
I'm running 335/30r18 bfg rivals on 18x12 forgelines. I don't recall bs or rear end width, but it's centered in the well. I'm running a Schwartz chassis. I'm at about 10-12mm between the sidewall and inner well on the front side (3/8"-1/2").
I have about 5/8" on the outside, but I could easily cut some of the quarter wheel lip or roll them some.
Thanks in advance!
Old 08-17-2017, 09:55 PM
Anyone??
Old 08-17-2017, 10:30 PM
craig510's Avatar
craig510 craig510 is offline
Remove the springs and cycle the suspension to see if it rubs. Easy.
Old 08-18-2017, 07:23 AM
dhutton dhutton is online now
I think this is normal. You could roll your lips and add a 1/4" spacer to pick up a little more clearance. I would not worry until you actually drive the car. It may rub a little approaching steep inclines but should be fine otherwise.
Old 08-18-2017, 11:12 AM
Ron in SoCal's Avatar
The centering device on the Schwartz chassis (panhard bar, right?) should keep the rear end stable and therefore limit side to side movement - but you still get just a little. Next up is any sidewall flex. I'm not sure how much but as Craig and Don mentioned, cycle the suspension one side up / other down on each side without the shocks / springs connected and see if there is any rub. Bear in mind, your shock compresses only so far which will limit the ability of the tire to go into the wheel well and rub. If no rub, your existing clearance and the extra 1/4" lip roll should do you fine.
Ron in SoCal
69 Camaro in progress
Old 09-03-2017, 07:17 AM
I'll see if I can get out and do that today. I know several guys run 335s on the rear and it just seemed tight. Thanks for the reply.
I thought about this as well. Even an eighth inch spacer plate would be something. I didn't cut my wheel studs yet so should be fine there. I bought the eastwood fender roller so may give that a shot as well, thank you.
Thanks for the reply. It's a triangulated 4 link, so should not have to much side to side.
