Old 10-12-2018, 05:50 AM
Brianstanford Brianstanford is offline
Originally Posted by Jimmy Sean View Post
Not sure I'd do that, wouldn't it heat soak and then take longer to cool? The heat reflective tape, the gold or silver work better at reflecting the heat?
i was thinking about the gold or silver tape, wish it came in black
Old 10-16-2018, 02:09 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Great looking build Brian! You've through quite a bit of life's trials and tribulations during this process. Enjoyed reading your thread. Way to keep at it!
Brent
The Following User Says Thank You to Ricochet For This Useful Post:
Brianstanford (10-17-2018)
  #93
Old 10-19-2018, 02:06 AM
Looking for help on the radiator hoses
griffin rad with in and out on same side
corvette ls2 motor
any suggestions is appreciated
Instagram @brianstanford
Old 10-19-2018, 06:51 AM
dhutton dhutton is offline
corvette ls2 motor
Lower hose ACDelco 24403L trim to fit.
Upper hose pretty sure a section of this will work. Gates 22358
Brianstanford (10-22-2018)
  #95
Old 10-20-2018, 08:28 PM
Gmachine1911's Avatar
corvette ls2 motor
I went with a couple from NAPA. Looks like your radiator layout is really similar to mine. I've got part numbers and pics posted on page 11 of my build thread if it helps...Nice project, btw, been following along!
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
The Following User Says Thank You to Gmachine1911 For This Useful Post:
  #96
Old 10-22-2018, 05:05 AM
Thanks guys!
Old 10-25-2018, 05:26 PM
Upper and lower radiator hoses. Both had to be cut a little to fit
Old 10-25-2018, 05:27 PM
Tipton clutch master cylinder reservoir
Old 10-25-2018, 06:30 PM
glassman's Avatar
glassman glassman is offline
I used self etching primer on mine. Then rattle canned it matte black. Both sourced from a body shop paint supplier.
https://lateral-g.net/forums/showthr...assman&page=48
post#472
Mike
The Following User Says Thank You to glassman For This Useful Post:
Brianstanford (10-26-2018)
  #100
Old 10-26-2018, 10:05 AM
rickpaw rickpaw is offline
You're making great progress. Looking forward to seeing it in person.
Tu Ho
