Old 07-14-2018, 03:27 PM
Brianstanford Brianstanford is offline
Originally Posted by will69camaro View Post
Wow definitely a wild couple years there. Glad you were able to keep the camaro dry! Good on you for putting it on the wooden cribs or you'd have had water inside and been re-doing some work!
Congrats on the healthy baby boy!
Onto car stuff, wheels being far forward, are your 4 link arms adjustable? Looks like you need to lengthen them to bring the wheels further back into the wheel wells. I had to center up my DSE stuff similarly.
Yes it has been a wild couple of years.
Thank you! He's our first
The lower 4 link bars are the fixed ones. Was thinking I need to get the adjustable one's
Old 07-14-2018, 04:37 PM
Gauges in, PSI harness integrated with chassis harness, Cooling fan relays, Main power breaker, Ricks resto mod tank - forgot the strap liners - will install, fuse block, VHX gauge controller and PCM in glove box. Detroit speed drive by wire pedal mount, 2 much tank vent
Old 07-15-2018, 08:47 AM
joeko23 joeko23 is offline
Great build and you are super neat with the wiring and labeling. What are you using for fan control?
The Following User Says Thank You to joeko23 For This Useful Post:
Brianstanford (07-15-2018)
  #34
Old 07-15-2018, 06:16 PM
Have a Griffin ExactFit rad combo with dual fans. It came with the relay kit. The fans will be controlled with the PCM with temps set for on/off
http://www.griffinrad.com/load_detai...key_id=6-00048
Old 07-15-2018, 07:04 PM
glassman's Avatar
glassman glassman is offline
Nice thread and great write up. Thanx for taking the time to do so.
the ups and downs of life. Good times and bad times, living life to its fullest while playing with our "legos" from time to time in our garages!!
Congrats on the little one, they sprout fast dont they?!?
cheers, mike
Mike
The Following User Says Thank You to glassman For This Useful Post:
  #36
Old 07-15-2018, 07:45 PM
cheers, mike
You're welcome. Gotta make the best of it and keep moving forward! Thank you, yes they do!
Old 07-15-2018, 08:39 PM
rickpaw rickpaw is offline
Congrats on the little one.
That's a really nice wiring job you've got there. Hope to see the car at local events.
Tu
Tu Ho
The Following User Says Thank You to rickpaw For This Useful Post:
  #38
Old 07-15-2018, 10:14 PM
Tu
Thanks!
I need to get up to one of the events to meet y'all and hang out. Your firebird is looking good with "part 2" upgrades!
Old 07-17-2018, 06:57 AM
Originally Posted by Brianstanford View Post
Thanks!
Thanks. It's been a long process with the 'bird. Started out as a 6 speed swap, then snowballed into a full on mechanical re-do.
Tu Ho
Old 07-17-2018, 12:16 PM
F'in mine's Avatar
Hey man, I'm happy for you considering all you've been through with the flooding.
Car is looking great!
Just wondering about the brake master you're using, I've looked online and found that most are plumbed on the passenger side, what S10 did yours come from?
Thanks in advance.
Simon
1969 Camaro SSRS
Simon
