Old 08-13-2019, 07:27 PM
Originally Posted by Matt@BOS View Post
No doubt! More volume is always better.
With regard to this post, if "behind the inner fender" means cut into the cowl, then I'd recommend going with a 3 gallon as well since you're going through the trouble of making something fit.
On a side note, I'd be curious to know if Steilow added to the Peterson reservoir on his builds. All of the ones I remember seeing mounted the dry sump against the core support, and if my memory serves, they were all 2.5 gallon because there is no room to go any deeper.
Matt
That's what she said....
The Following User Says Thank You to raustinss For This Useful Post:
Flash68 (08-14-2019)
Old 08-14-2019, 08:53 AM
colorado80439 colorado80439 is offline
Matt
Ya Matt that's the plan, just like this pic
http://assets.superchevy.com/f/227484914.jpg?
Just trying to determine the best way to route to oil lines, Peterson (among others) make an AN fitting adapter for the LS7 oil pan. With the DSE subframe and DSE headers I'm thinking of running a hard oil line through the subframe
Thanks Dave
Old 08-14-2019, 08:57 AM
Old 08-14-2019, 01:56 PM
Matt
Hellfire and Gunner both have 3 gallon oil tanks.
Old 08-14-2019, 05:43 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
2.5 gallon... 3 gallon, same thing
I'm not kidding. there's one part number 08-0025-ATS, and some sites list it as 2.5 while others list it as 3. As far as I can tell, we're talking about the same thing.
http://bestofshowcoachworks.com
(760)480.0227
1969 Camaro - always broken GM Design winner
1965 Mustang - widebody fastback
2006 Coyote swapped "Rental Car"
Up next:
Steve's GT40
Old 08-14-2019, 05:47 PM
Except 12 quarts does not equal 2.5 gallons
