Old 11-14-2018, 12:46 PM
Yelcamino's Avatar
Yelcamino Yelcamino is offline
I'm finally back at on the Chevelle. Since my last update a lot of things have been pushing this project on to the back burner. We replaced the gravel driveway with concrete (around 146 yds!), got a new front door on the house, I converted the El Camino over to a Ridetech coilover system with a set of custom built (by me) triple adjustable shocks, and we drove to Vegas to attend SEMA. Over the last few days I was able to get most of the main cage structure tacked in place. I've never installed a cage before and I'm using a kit (from Ron Sutton). I don't have any experience to say whether or not the kit is any good (not that it matters anymore), but I think it will be ok for my use.
20181114_114640 by Yelcamino, on Flickr
20181114_114652 by Yelcamino, on Flickr
Once I'm done with the main cage, the body is coming off and the chassis is going on a rotisserie that I'm borrowing from Tom Farrington. With access to all the tight joints I should be able to weld it much better than in the car. While it's on the rotisserie, I'll also address some areas under the chassis that were hard to get at while it was on the table.
It may not be Vorshlag quality, but I'm trying my best!
Herb
1966 El Camino LS408/T56Magnum
1966 Chevelle 509/T56Magnum
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 11-14-2018, 01:44 PM
SSLance's Avatar
SSLance SSLance is offline
Sorry I never got to see you while at SEMA Herb...guess we just never crossed paths. Good to see you back on the Chevelle...good luck finishing up the cage. Looks like a LOT of work...
Lance
Old 11-15-2018, 09:06 AM
Yelcamino's Avatar
I'm sure we'll cross paths eventually Lance! I visit friends in Phoenix occasionally...
And yes, the cage is a lot of work especially since there were no instructions or diagrams saying which tube goes where, but I'll make it work!
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 03-20-2019, 07:31 PM
Yelcamino's Avatar
In case anyone was wondering, I'm still plugging away on the Chevelle but I've been very lazy with thread updates. Instead of boring you with all the little details, I'll just post the most current stuff...
Here it is on the ground for the first time in a while. I had the Forgelines widened to 18x11 and 18x12. The tires are a used set of 315s and 335s I got from Ridetech. They're good enough to roll around the shop and even for some test drives when the time comes. I have the mock up engine in place mounted to the Quicktime bell and T56. Engine set back looks good too.
20190317_210712 by Yelcamino, on Flickr
20190318_101809 by Yelcamino, on Flickr
20190318_101754 by Yelcamino, on Flickr
20190317_210552 by Yelcamino, on Flickr
20190317_210727 by Yelcamino, on Flickr
With the help of some friends, I made new steering arms.
20190318_101949 by Yelcamino, on Flickr
I've also been busy bending sheetmetal for the interior. Right now it's just screwed together to make sure it all fits.
20190214_190154 by Yelcamino, on Flickr
Finally, I got the fuel cell mounts figured out.
20190112_170316 by Yelcamino, on Flickr
20190112_170248 by Yelcamino, on Flickr
The next big task will be removing the body again, mounting the chassis on a rotisserie so I can complete all the cage welding and other various things that are currently tacked together.
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
The Following User Says Thank You to Yelcamino For This Useful Post:
camcojb (03-23-2019)
  #75
Old 03-22-2019, 06:58 PM
waynieZ waynieZ is online now
Nice work Herb.
Old 03-23-2019, 07:10 PM
silvermonte silvermonte is offline
Quick question, how are you handling the access to the distributor if you need to take it in or out? Im doing an S10 that has massive engine set back like yours and Im almost considering a LS engine just so I dont have to worry about that.
Miles Boyer
96 Corvette
91 V8 S10
88 Olds Cutlass
Old 03-23-2019, 09:53 PM
camcojb camcojb is online now
Nice work Herb.
X 1000.
Old 03-24-2019, 08:06 AM
What a beast! Nice work, Herb. Keep it up!
Old 03-24-2019, 11:12 AM
Killer Chevelle !
Old 03-24-2019, 04:36 PM
Yelcamino's Avatar
Nice work Herb.
Thanks!
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
