Old 06-17-2016, 12:02 AM
snappytravis's Avatar
snappytravis snappytravis is offline
Originally Posted by Sonar Chief View Post
Congratulations on the new additions!!!! Been getting any sleep lately? lol
Post pics when you can, take care of the family!
Michael
I will tell you this, It was tuff the first 3 or 4 months,, every 3 hours they where up, Finally they sleep all night,, Thanks I will put up some pictures
Old 06-17-2016, 12:04 AM
Originally Posted by Zoomin View Post
Best hurry and finish your car before the twins start sucking your bank account dry!
Love what you've done so far.
Oh ya,, I knew I better get it close to being done. Just waiting on interior. I am thinking I will be going back to the basic restoration projects.. lol byby dse, ame, Rushforth,,, hello Rock Auto..
Old 08-13-2018, 12:34 PM
Default Well it's finally done!
Here is a email that I have sent to a few guys on the car project. I have been going out to the garage this past week after babys go to bed and working from 9 til 12 or so,,, Just have the dash to finish up and all the rest of the interior is almost done..
Here are a bunch of pictures of the Camaro. I have been working on this car for 8 years off and on. I will give you a brief rundown. I made the deal on the car after it had been sitting for about 12 years. I bought it and got it running and drove it a few times. Then I decided that I wanted to build a car that I could drive on the highway with all the newer thing that new cars have. I replaced the quarter panels, rear trunk pan, outer door skins. and completely cut out the firewall and welded a solid piece in there to smooth it up. I shaved the drip rail.. little lip on edge of roof. ( new cars don't have that).. I installed late model gm door handles. (smooth look). I tucked the rear bumper into the body and narrowed it aprox 3". I resized the window openings to install windshield molding like new vehicles.
The engine is a 2010 Camaro ls3. It started as 376 ci. It is now 413 ci and has a supercharger added. The front drive pulleys. AC, P.S., is all custom built. I have a stainless steel fuel tank with a Cadillac cts fuel pump. It has to use a little fancy fuel pump controller that controls voltage to pump,, More voltage more = fuel.. It has a 6 speed transmission similar to what the new Camaros have. I also installed a hydraulic clutch setup. Had to have a custom built aluminum driveshaft made to handle the horsepower..
There is a picture of the frame setup. It uses newer 2005 style corvette A arms and a rack and pinion setup. I have 14 inch front brake rotors and 6 piston calipers. Comparable to newer vette. The rear end is a ford 9 inch with 3:89 gear ratio. Should cruise at 80 around 1300 rpm. If you look fuel tank is notched on the corners for the exhaust to clear. I took the car to ft Collins and had 3" stainless exhaust put on. I have a custom built radiator with dual fans and power steering and oil cooler built in.
The wiring,, I have one wiring harness that run the engine, I have another wiring harness with the fuse box that runs the headlights and taillights and all the interior stuff. I installed halo style headlights that have a white outer ring. Similar to newer vehicles. I installed led parklights, They have a white outer ring as well, Looks like Daytime running lamps. I installed led taillights to match all the other led stuff. The gauge panel is a touch screen that is fully programmable to whatever gauges I would like to display, layout and colors of the gauges as well. It's like the touch screen radio in new cars..I still need to figure out stereo. I installed power windows and locks, and of course if you have power locks you need a key fob to run them,, Push the button doors unlock and interior light comes on for 60 seconds.. Headlights flash as well. I also installed a power trunk latch.. I installed a ac and heater unit that is electronic. No cables like old cars..
The interior is ordered,, finally,, It took me about two months to figure out what I wanted to do. It will be black vinyl with sued on the bolsters and red inserts in the middle of the seats, with black grommets up the center. I ordered a center console that will be black and red as well. The door panels will be black with a red insert as well and grommets in them, Red stitching in everything. So the riverton carshow will be July 19, It will take 5 weeks to get interior. That leaves aprox 3 weeks to get it done... Should be interesting.
I know a lot of people like the original stuff, I do myself as well. This car was not a ss or rs or had any special options. I had always wanted to do something custom,, This was the one, I figure I have at least 3 to 4 thousand hours in this car. I will probably never have the time to build one like this again, now the twins are here. I am good with that I would rather spend the hours with them then the car..
Well hope you enjoy the pictures, some of them are for reference for me to know how stuff goes together. I built the whole car, then tore it completely down and painted frame and firewall and then reassembled,
Talk to ya soon,,
https://l.facebook.com/l.php?u=https...tZ2-atcWHFiBdI
The Following User Says Thank You to snappytravis For This Useful Post:
waynieZ (08-13-2018)
  #64
Old 08-13-2018, 01:16 PM
I love what you did Travis, I always check back on your build. I'm hoping life will give me a little break so I can at least get mine started.
Beautiful pictures.
Old 08-13-2018, 01:21 PM
thanks Wayne, I sure couldn't of done it without the help of this website, hope you get freed up to get back to work on your car soon!
Old 08-13-2018, 01:41 PM
Thanks. Where did that front spoiler come from?
Old 08-13-2018, 05:29 PM
Its all Anvil auto stuff, I bought a bunch of stuff from another member on here..
Old 08-14-2018, 04:07 AM
130fe 130fe is offline
Thumbs up
Great looking interior! Is that a TMI console?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 08-14-2018, 08:10 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Beautiful car! Good job!
The Following User Says Thank You to Josh@Ridetech For This Useful Post:
snappytravis (08-14-2018)
  #70
Old 08-14-2018, 02:55 PM
Yes it is. Thanks I picked all the colors.. I am happy with the quality..
