Old 06-10-2014, 01:49 AM
tom091074 tom091074 is offline
It's an old post that I just re-posted for Glassman.
He was trying to figure out what tires he wanted to run.
My bad I didn't even look at the date. Bad habit.
Old 06-10-2014, 01:36 PM
syborg tt's Avatar
I was in a similar situation, ended up making our own mounts.
I actually tossed all of the stuff in the scrap metal bin and then bought the Ride Tech bracket.
marty-mj
Old 06-10-2014, 01:37 PM
syborg tt's Avatar
Not to worry it was very nice that you offered to help.
marty-mj
Old 06-10-2014, 01:39 PM
syborg tt's Avatar
Right now i'm running a KDW 245/17 up front and don't have enough tire and i'm running a 275 in the back. I want to run a 315 and my next door neighbor is running the Nitto 05 315/17 on his and its exactly 12" wide, od of the tire, not the tread or seating bead.
I plan on mini tubbing it but its runnin sooo good with the leafs, i dont wanna change it. Only want to change the rims tires to get more meat, for looks and performance....
I tracked it a few weeks back with Greg and Seig and the car ran fantastic, just need more power and a little more grip, but shes very predictable.
Keith (Custom Works) did the clip, steering, Speed tech, coil-overs, and the Holley/Hooker swap and the car handles very good and is very controlable/predictable......fun to drive.
Went for a 45 min pedal today, 106* out, ugh....good thing i gotta large water like tub in the back yard....
If i had to do it all over again I would just cut out the old wheel tub completely and have a more rounded tub made and bond it to the quarter because you still have to clearance the outer wheel tub when you put a 27" tall tire on the car.
ps Rode my Farly Fat bike with the new Bluto suspension fork Saturday & Sunday and I feel like a kid again. It was a freaking blast !!!
marty-mj
Old 06-10-2014, 08:29 PM
Rick D's Avatar
Rick D Rick D is offline
So is this what you got now??? Very cool!!!
Rick
Old 06-10-2014, 09:39 PM
glassman's Avatar
glassman glassman is offline
Those things are sick!!!! I haven't seen any yet!Boy has it sparked my interest.....
Mike
Old 06-10-2014, 10:37 PM
syborg tt's Avatar
I have last years version with a few more upgrades. Wheels are carbon Fiber and weigh only 2lbs each. Which really helps getting the beast moving and stopping.
You should come ride with us.
marty-mj
Old 06-11-2014, 01:20 AM
Always willing to help.
Old 06-11-2014, 10:36 AM
So this does work or is an option? I was thinking about something like this eventually simply to gain as much clearance as possible to go as low as I can. I couldn't think of a reason to not do this, even to the front, but then again, I'm no expert.
Old 06-11-2014, 10:47 AM
syborg tt's Avatar
In the rear Kenny re leaved (insert hammer) some of the outer inner fender to gain clearance when we swapped to the 27" tall tire a couple weeks before Sema. I like the look of a 27 rear and 26 front much better as the the rear wheel opening is slightly larger.
As for the front when you down as low as we are the inner fender becomes the problem. However the Anvil inner fenders give more "Height" clearance and also turning clearance for a 275 or even a 295.
marty-mj
