Old 08-04-2019, 02:16 PM
May I ask the center to center measurement for the ears on the caliper bracket? I want to see of your calipers are the same as mine.
Old 08-15-2019, 09:22 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Thumbs up Solutions
Originally Posted by badazz81z28 View Post
Theres a thirst for more info on these kits. They now come as bolt on which is very nice. Do you offer axles? Is there an inner axle seal with the kit? Will the ear spacing on the caliper bracket fit aftermarket brakes like Baer 6P and SS4?
Thank you for your interest. You are correct, in addition to the Weld-On kits as you see here, I offer Bolt-On kits for the follow type housing ends regardless of what housing they are attached too.
* Big Bearing Ford/Torino
* Moser 7900/Strange H1143
* GM Car 10/12 Bolt (except Impala)
* 98-02 F-body (coming soon)
https://millerbuiltusa.com/bolt-on-k...ication-chart/
Yes, axles are offered as well (sold separately). Most applications will receive MillerBuilt spec Hytuf axles, manufactured by STRANGE. Smaller spline count differentials (such as 28 spline or less) will most likely require 300M at a slight increase in price. Variables like car weight/usage,tire size/compound, Hp/Trq, etc. will determine this.
No inner axle seal required, nor do I recommend for street driven vehicles that will not see regular inspections of the inner seals.
https://millerbuiltusa.com/solid-axles/
I offer each application listed above with different caliper brackets to accommodate various brake manufactures.
Currently I can accommodate any brake kit made for:
C5/6/7 Corvette - OEM or Aftermarket (Wilwood/BAER/AP/etc.)
G5/6 Camaro - OEM or Aftermarket (Wilwood/BAER/AP/etc.)
*Although the BAER SS4+ is not offered in any of the above applications, I will soon offer a caliper bracket for folks who currently utilize a BAER SS4+ brake kit and are looking to re-purpose onto one of the above listed MillerBuilt Full Floater Kits. This is what was done for the Ridetech 48hr Camaro...
Hope this answers all your questions.
