Go Back   Lateral-g Forums > Events > Track and Driving Events
Old 08-11-2016, 01:04 PM
Flash68's Avatar
Flash68 Flash68 is offline
Chad wins.
The end.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 08-11-2016, 01:52 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Originally Posted by jeff71 View Post
I'd love to see your list of items tools, parts etc for a road trip like this?
Hi Jeff,
My list is below. All of the tools fit in the trunk and I keep all my clothes/personal items on the back seat.
  1. 1.5 ton aluminum floor jack
  2. 2 jack stands
  3. 2 doubled up 2x4 boards (needed to efficiently jack up the front end due to the low ride height). Also serve as wheel chocks when jacking the rear end.
  4. Cheap cigarette lighter plug air compressor
  5. Folding chair with sunshade
  6. Star wrench (tire iron)
  7. Extra oil
  8. Drill with socket for lug nuts
Tool box with:
  1. Typical assorted pliers, screwdrivers etc.
  2. Full set of metric & SAE shallow and deep 3/8 drive sockets & wrench
  3. Set of common metric & SAE 1/2 drive sockets & wrench plus 1 1/8" socket for front spindle
  4. ft lb torque wrench
  5. Full set of SAE & std allen wrenches
  6. Set of SAE wrenches from 1/4" up to 3/4"
  7. Set of metric wrenches from 10mm to 17mm (10, 15 & 17 most common used sizes on my LS motor)
  8. Large crescent wrench that covers sizes from 3/4 or 17mm to over 1"
  9. Pipe wrench
  10. Multi meter
  11. roll of 14 gauge wire
  12. electrical & pipe tape
  13. wire stripper & pliers
  14. Hammer!!
Extra parts
  1. Couple of common 35a STDT relays (works on every relay on my car except electric fan
  2. Extra 70a STST heavy duty relay for electric fan
  3. Extra 1156 & 1157 bulbs (don't want a last minute burn out costing D&E points)
  4. Extra fuses
  5. Extra sway bar end link kit (has broken once mostly my fault from panhard bar adjustment)
  6. Extra bleeder screw kit (has broken once)
  7. BP40 Willwood track pads for front and rear
  8. Generally, I don't bring much in the way of spare parts as I have had great luck.
I did that off the top of my head so I might be forgetting some things.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 08-11-2016, 03:25 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Sounds like a great adventure!! Thanks for sharing!!
Curtis
Old 08-11-2016, 09:01 PM
130fe 130fe is offline
Looks like a great time Chad! Thanks for posting the pics. That is a great list for tools to take.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 08-17-2016, 10:15 PM
CarlC CarlC is offline
Originally Posted by Chad-1stGen View Post
Hi Jeff,
  2. 2 jack stands
  7. Extra oil
Tool box with:
  9. Pipe wrench
  10. Multi meter
  14. Hammer!!
Extra parts
  4. Extra fuses
We might need to make that list just a bit bigger ;-)
http:www.vaporworx.com
Old 08-17-2016, 10:32 PM
Chad wins.
The end.
What he said --- in SPADES!!!
Well done buddy!!! I know it's hard cause I did that SOB TWICE last year in the '33
Old 08-17-2016, 11:19 PM
Sieg's Avatar
Sieg Sieg is offline
Chad you're climbing the ladder of legendary status in the Pro Touring arena.
Old 08-18-2016, 12:00 AM
MtotheIKEo MtotheIKEo is offline
This is exactly what a pro-touring car is in my mind. Congrats on the successful trip Chad, it's awesome seeing you use your car as intended.
Old 08-18-2016, 07:38 AM
califconstruct's Avatar
califconstruct califconstruct is offline
Cool trip, love the documentation. That LS sure can take a lickn'
