Old 05-02-2017, 10:04 AM
1970RT's Avatar
1970RT 1970RT is offline
Originally Posted by andrewb70 View Post
Great start on the Charger and I also enjoyed the write-up about the Suburban!
One suggestion: cut down the size of the pictures here. You may have a giant monitor at home, but on a smaller monitor it is a little annoying having to scroll sideways. A good size is around 1200 pixels across for embedded pictures. Just a suggestion.
Thank you, and I appreciate the suggestion. I've been uploading from Tapatalk on my phone. I'll knock down the size from 'best' to 'medium'.
David
Old 05-03-2017, 06:18 AM
1970RT's Avatar
The march toward media blast continues.
Doors removed to save weight and improve my 60ft times.
3M strip discs make a lot of dust, so I worked outside. Cowl, doors, and half the roof were all bare metal. Also pulled the last remaining brackets and hardware.
In the disassembly, I found the frame rails and crossmembers were filled with a fine sandy dirt. No kidding, there was a full dustpan of junk that rattled out as I rolled the car.
All hail compressed air:
Finished roof
Fenders done:
Lots more prep still to go.
David
Old 05-03-2017, 07:21 PM
gofastwclass gofastwclass is offline
Looks like a fun project.
I feel your pain on the previous owners repair attempts. I wonder if the same guy owned or worked on my 1961 Impala. At least we both know how to fix these things.
I build my own junk...
Old 05-04-2017, 05:55 AM
1970RT's Avatar
I'm reminded of the saying "perfection is the enemy of good enough," but it's odd to think of what passes for acceptable quality in some circles.
You're right. I'm glad the car is mine, and I can take my time to make it right.
David
Old 05-04-2017, 03:27 PM
1970RT's Avatar
...and about those quarters.
Lots of old rust and rot and rat scat. My rational was, "why have them blast and prime panels I've already planned to remove?" The passenger side revealed a scabbed on patch using lots of adhesive. The inner structure appeared solid.
The driver side was much less dramatic. Prying the panels off the rockers confirmed they're fairly intact, if a bit corroded.
The inner sail panels have a lot of that resin. I assume the PO used it as a backing to mound up body filler on the outside:
Once ready, we loaded her up on the trailer, and I took it to North Texas Customs.
I also took the fenders and doors, but I still have some work to do on the hood and deck lid, and they can be handled individually.
They blast with a 40/80 grit garnet, and scrape off what that doesn't get - underbody coating, resin, etc. To avoid stress relieving and warping, only one side of a panel is blasted - they treat and sand the underside of the roof chemically and/or mechanically before priming. Turns out, this process is what the shop is best known for, and they have a good reputation from members on a few forums, the HAMB in particular.
Big step for the car.
David
Old 05-05-2017, 09:34 PM
1970RT's Avatar
Back in black
David
The Following User Says Thank You to 1970RT For This Useful Post:
syborg tt (10-28-2019)
  #17
Old 05-08-2017, 09:29 AM
1970RT's Avatar
Continuing work up front, I started patching some of the through-rust on the rails. The rails are all 14ga, so patching is a lot like sheetmetal repair.
Marked up rail highlighting damage:
The rail under the bump stop brackets had spotty pitting; more pin holes to repair:
Also noticed the inner frame braces were deeply pitted, so lots of evidence that water collected in this area and never made it to the drain holes slightly farther back.
Drilled the rust packed spot welds and cut out the neighboring pitting:
Fit the patch:
Ready for bump stops.
Wrapping up some repairs on the inner part of the rail - pitting, spot welds, and porosity:
David
  #18
Old 05-09-2017, 08:59 AM
Jimbo1367 Jimbo1367 is offline
Default repairs
Glad to see you doing a great job
Old 05-10-2017, 07:12 AM
1970RT's Avatar
Originally Posted by Jimbo1367 View Post
Glad to see you doing a great job.
One piece at a time.
David
Old 05-10-2017, 08:03 AM
1970RT's Avatar
Taking a closer look at the UCA brackets, it looks like there are some cracks in those welds, too. I'm prototyping on the driver rail, and will duplicate on the other side.
Decided for a change of pace, and started on the battery tray repair/modification. Since the battery will sit in the passenger rear of the trunk, I figured I would reclaim these few cubic inches for the engine bay:
David
