Old 10-02-2017, 11:53 AM
NAPA 68 NAPA 68 is offline
Great info!
Old 10-02-2017, 12:17 PM
71RS/SS396's Avatar
Sooo....When will the "Stielow Bleeder" be available for purchase?
Old 10-06-2017, 12:36 PM
CarlC CarlC is offline
Mark, where did you find the reservoir cap?
http:www.vaporworx.com
Old 10-06-2017, 01:59 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
https://www.amazon.com/Motive-Produc.../dp/B00YS8JW54
Donny
Old 10-06-2017, 03:27 PM
Boss 5.0's Avatar
Boss 5.0 Boss 5.0 is offline
I use one of these for filling cooling systems....
https://www.matcotools.com/catalog/p...TEM-AIR-PURGE/
From what you are describing and show it is almost exactly as this works for cooling. It draws vacuum down and makes sure there are no leaks, then with the hose dropped into the coolant you open the valve and it forces it into the entire system. I haven't had to burp a system since 1996 when I bought this.
A system like this for brake fluid would be incredible!!!
Copper Hill Rod & Custom
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy R10
Glenn
Old 10-07-2017, 09:11 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by dontlifttoshift View Post
This one works better
Power Probe BA04 Brake Bleeder Adapter https://www.amazon.com/dp/B0037668CI..._xYqT8ERFtwZLL
Seals a lot tighter.
Mark
Old 10-07-2017, 09:15 AM
Stielow's Avatar
I fought bleeding brakes for years. This system works great for me. If you don't do the vacuum part and just the pressure part that works very well also. If you try it make sure you have a stock GM resivoir. I have no idea what will happen with aftermarket parts.
Mark
Old 10-12-2017, 04:42 PM
carbuff's Avatar
carbuff carbuff is offline
Mark,
I really like this idea! As with many ideas, it seems so logical once you see it, but I had never thought of it. I have a few follow-up questions please:
  • Have you attempted this same method on your hydraulic clutch system?
  • What tank did you use on the pressure side to hold the fluid? It looks like a Canton tank, with a modified top (to seal) and bottom (for a larger fitting)?
  • Is 50-psi pressure a 'magic' number for the pressure side? I'm curious if a lower-pressure would be sufficient (perhaps for the clutch which is not as robust of a reservoir)?
  • Finally, when you topped off the final fill, did you have to suck fluid out to achieve that level after you released the pressure? You mentioned an extension on the bottom of the cap, but it's not clear to me how that helps...
Sorry for all of the questions, but I would like to replicate this in the near future as I'll be filling my own brake system soon. I'd prefer to learn from experience vs. having to do it by trial and error. I have the cap on order (should have been here already but for a shipping snafu...).
Thanx for sharing!
Old 10-12-2017, 10:44 PM
Musclerodz's Avatar
The phoenix bleeder does pressure or vacuum but not to this degree. Something I need to look closer at before we do the next brake system.
Mike Redpath
Musclerodz & Customz
facebook page
Old 10-14-2017, 10:55 PM
Thanks Mark.
