Old 10-05-2019, 10:15 PM
Brianstanford Brianstanford is offline
Originally Posted by Beechy View Post
99% of driving miles are run straight ahead, caster doesn't affect the angle of the tire relative to the pavement, so does not affect wear. It DOES improve stability and "return-to-center" after turning.
During turns, caster tilts the outside wheel inboard at top so preventing tire "tuck under" thereby improving tire life.
Extreme caster (8* and more) will cause tire wear and is too much on a wet road with low profile tires.....car will PUSH BAD.
Four degrees is very conservative.
Everybody needs "slalom" when that autonomous Tesla comes out of the side-street.......not just for autocross guys.
VERY simple explanation (there are other factors at work)::::Caster is the difference between shopping cart wheel flutter, and a bicycle when u push it along using the seat only. Caster being the angle of the head stem where the steering bearings are.
Thank you! I get it better now
Instagram @brianstanford
Old 10-06-2019, 02:24 PM
Originally Posted by Brianstanford View Post
Where at? Give me some details please
Sent on Instagram
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
2018 GMC Denali HD
The Following User Says Thank You to will69camaro For This Useful Post:
Brianstanford (10-06-2019)
  #183
Old 10-24-2019, 07:49 AM
Had to replace the pilot bearing last week....thinking it was my fault it went out, installed wrong. Anyways got it replaced with the bushing this time and things are good to go again!
Old 10-24-2019, 12:46 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Pain in the azz to get to.
Curtis
Old 10-24-2019, 12:48 PM
that ain't no lie! lol
Old 06-01-2020, 07:56 AM
Have a Griffin in it now and it’s been leaking on both sides where the tanks connect to the core.
Looking for a new setup. Let me know what y’all suggest. Thanks!
Old 06-01-2020, 10:16 AM
rickpaw rickpaw is offline
Believe it or not, I've been using a Champion radiator since 2011 and so far haven't had any issues.
However, I've been looking at the C&R set up.
Tu Ho
Old 06-01-2020, 08:49 PM
My brother runs a champion with good luck too
Old 06-02-2020, 11:24 PM
randy randy is offline
Small leak? If so just add the gm radiator tablets. It was actually suggested by a prc before and solved my buddies issue on his
Old 06-03-2020, 06:35 AM
dhutton dhutton is offline
Did you use wellnuts to install your radiator so it can move when it expands?
Don
The Following User Says Thank You to dhutton For This Useful Post:
1in1969 (06-09-2020)
