Old 10-08-2018, 04:52 PM
Brianstanford Brianstanford is offline
power steering pressure hose
earls -6 powers steering hose
2x xrp 90 degree -6 hose ends
earls -6 an to 18mm X 1.50 adaptor
earls an adapter to power steering pump 961961ERL
return hose i used a edelmann 39106 fitting and rubber hose
Old 10-08-2018, 04:55 PM
air intake. 4'' spectre tube, summit silicone hose couplers and a 7'' airaid dry filter
Old 10-08-2018, 07:04 PM
aany001's Avatar
aany001 aany001 is offline
Originally Posted by Brianstanford View Post
Motor and trans together. Had to put an 1/8" shim behind the slave cylinder
Excuse my messy 2 car garage haha!
Waiting on polyurethane motor mounts to show up and then I'll be stabbing the motor/trans in the car ��
Why did you have to put a shim behind the slave cylinder? What a great build. Im subscribed!!!!
Old 10-08-2018, 07:11 PM
thank you!
quote from tick performance-
During your next clutch install, determine if your slave cylinder needs to be shimmed or not. To do so, you need to take two measurements:
Measurement "A" is the distance between the surface of the bellhousing that meets the transmission to the tip of the pressure plate fingers. To get an accurate measurement, the clutch must be torqued properly.
Measurement "B" is the distance between the throwout bearing surface to the transmission surface that meets the bellhousing. To get an accurate measurement, the slave spring must be removed and the bearing must be fully seated at the bottom of it's travel; resting on the slave's base.
Once you've got your two measurements, make sure that measurement "B" is ~1/16" to 1/8" LESS than measurement "A". If you come up with more than 1/8", add an appropriately sized shim between the slave and the transmission in order to get the measurements where they need to be.
If there is no difference between the two measurements, or if "B" is greater than "A", there could be a problem with clutch engagement which could result in premature clutch slip and eventually a total failure.
my #'s were-
trans side 1 7/8''
motor side 2 1/8''
1/4'' gap
need 1/8'' shim
Old 10-08-2018, 07:58 PM
aany001's Avatar
thank you!
my #'s were-
trans side 1 7/8''
motor side 2 1/8''
1/4'' gap
need 1/8'' shim
Wow that's really good info there. Im running a stock T56 and clutch and had no issues with clutch engagement but did go through 2 slave cylinders 1 new and 1 used both GM pieces ( both leaked and ruined my clutch disc) I removed the shim that I had and so far no issues with 4k miles. Weird huh
Maybe a fluke thing
Old 10-08-2018, 08:02 PM
Maybe a fluke thing
that is crazy! hopefully it works out for me with the shim. defiantly don't want to buy another clutch or slave lol
Old 10-09-2018, 07:34 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
Hard to tell if the intake tube is in front of the fan or not. It looks very similar to mine and i had to raise mine up above the fan. If it is in front of the fan it will get heated when the fan is on. Problem being is the mass air is reading the incoming air temp and the air gets heated directly after the mass air. It could cause a spark knock because the ECM thinks the air temp is lower. Any-who something to think about.
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
The Following User Says Thank You to Jimmy Sean For This Useful Post:
Brianstanford (10-10-2018)
  #88
Old 10-10-2018, 11:53 AM
Thanks! It is in front of the fan a little bit. Didn't even think of heat soak on the intake tube.
Old 10-11-2018, 08:04 AM
F'in mine's Avatar
F'in mine F'in mine is offline
This might help in keeping the intake tube as cool as possible......exhaust wrap, plus if you're not into polished aluminum look it tones down the shininess of the tube with a few colour options.
1969 Camaro SSRS
Simon
The Following User Says Thank You to F'in mine For This Useful Post:
Brianstanford (10-12-2018)
  #90
Old 10-11-2018, 04:06 PM
Jimmy Sean's Avatar
Not sure I'd do that, wouldn't it heat soak and then take longer to cool? The heat reflective tape, the gold or silver work better at reflecting the heat?
