Old 07-22-2018, 07:36 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
Default 69 Camaro 427 Build
I've started a new project recently, a 1969 Camaro coupe. This weekend I decided to pull the engine. After some research on the casting numbers. I found that it's a 427 Block with a 2 bolt main. The oval heads are from a 396. I figured out that the 427 was originally a 335 hp motor from a 69 impala. Car also came with Saginaw 4 speed. My question is what is a good combination of cam, intake, and carb? I want it to have power and at the same time to have that rumble. If you guys have a similar setup feel free to post the parts you used and how it drives. Thank you
1967 Camaro RS
1969 Camaro coupe
